Old 05-27-2019, 11:58 AM   #1
Black tank flush for 2019 Salem 27REI
Black tank doesnít drain real well. Is there a black tank flush setup on this model?
Jtmavs is offline   Reply With Quote
Old 05-27-2019, 12:24 PM   #2
Mr. Dan's Avatar
Originally Posted by Jtmavs View Post
Black tank doesn’t drain real well. Is there a black tank flush setup on this model?
I don’t think a black tank flush will make the black tank drain faster. Maybe your valve isn’t opening completely or you have construction trash, etc., stuck in the outlet.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 86; booked = 0
Old 05-27-2019, 12:52 PM   #3
bikendan's Avatar
I don't think Salems come with a factory black tank flush.
Equalizer WDH
Old 05-27-2019, 01:04 PM   #4
Retired Old Fart
dward51's Avatar
If the above does not reveal the problem, then look at the roof vent. There needs to be good airflow in for the tank to drain properly as well.
One other thought, if you have one of those inexpensive flexible inspection cameras, you may want to snake it either up from the drain valve end or down from the plumbing end to see about a physical obstruction. It's not impossible that the plastic piece from where the cut the openings may have fallen inside the tank and been left. It could be partially obstructing the drain inside the tank.
If you don't have one of those, look for an "endoscope" for your type of cell phone on ebay or Amazon. Should be $25 or less.
I've got one for my Android phone and also a dedicated inspection camera (it was an inexpensive model - around $50). The 2 of these have saved my butt many a time in both the boats and trailer. Makes it possible to see behind obstructions and inside small holes to follow a wire, hose, etc... Beats having to pull a panel off to find it's not really where you need to be doing the work. Well worth having one in your toolbox.
Just the 2 of us in a...
2015 Freedom Express 246RKS
2002 GMC Sierra 1500
dward51 is offline   Reply With Quote
black, black tank, black tank flush, flush, salem, tank
