Old 06-24-2018, 01:53 PM   #1
Nikola's Avatar
Black water dump valve
Hi all.
I purchased a 2018 Salem Hemisphere Hyperlite 29BHHL travel trailer a few months ago, and for the life of me can't find the black water tank drain valve. The 2 grey water tanks valves are tied in to the 3" line which is, I'm guessing, the one that runs back up to the black water tank. The outer stickers indicate that the black water tank valve should be right above the left side grey water valve, however it is not.
Am I missing something? or am I just blind. Any chance one of you fine people who have this similar trailer can snap a pic of where its located for me. I'll put up a pic of the underside are on mine when I get back to it later today.
Thanks in advance. This is my first new trailer, and will probably be asking a lot of dumb questions these next few months. Lol
Nikola
Nikola is offline   Reply With Quote
Old 06-25-2018, 08:38 AM   #2
SeaDog's Avatar
Looking at the specs for your rig you only have one gray and one black tank. so both valves are there. This is an edit I went back and looked at the specs and want to qualify my answer the specs show a total gal of gray and black so there may be a third tank.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 06-25-2018, 08:59 AM   #3
cavie's Avatar
Looking at your floor plan I think you have a gray and black behind the axels and a galley in front. So yes, you would need three valves. I could be wrong.
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
cavie is online now   Reply With Quote
Old 06-25-2018, 09:16 AM   #4
Blackrock's Avatar
What I am seeing on the specs for your trailer are a Black water capacity of 27 gallons and a Gray water capacity of 54 gallon. So I think you do have two 27 gallon gray tanks one for the galley sink and one for the shower and bathroom sink along with your black water tank off the toilet.
Looking at your layout I would guess the galley gray water would dump somewhere in the area that is under your slideout just ahead of the front axle.
2016 RAM 1500 - 2016 Keystone Laredo 265SRK
The road goes on forever and the party never ends.
Blackrock is offline   Reply With Quote
Old 10-22-2018, 08:42 PM   #5
It is located above the two gray tank handles. Ours didn’t come with the black handle or the screw holding on the rod came loose. The dealership’s tech had a spare one which I attached with a dab of lock-tite.
jrw711 is offline   Reply With Quote
black, black water, valve, water
