Old 09-28-2014, 08:46 PM   #11
scrambler44's Avatar
Originally Posted by youroo View Post
No on the (Slide supports). There is (1) switch for all your tank heaters,they are Thermo controlled. Yes you can manually adjust your Stab jacks. Youroo!!
I have a 2 6tbud and have the same jack set up as your I have looked all over for a manual way to raise and lower the jacks if the power option fails witch mine has already last month my slide awning and jacks all lost power but yet everything else worked just fine I spent two days racking my brain as to what caused this wound up taking ot to my local dealer and they spent over 50 hours and came up with nothing we called in a factory rep and they sent a repair tech from the factory luckily he found the problem afyer only a couple of hours it was only a wire in the ceiling that had come undone from the butt splice from the factory installation. I have a 2 6tbud 2012 that I bought in july of 2014
scrambler44 is offline   Reply With Quote
Old 09-28-2014, 08:55 PM   #12
B and B's Avatar
The tank heaters on the black and grey tank keep the valve from freezing so you can dump. Fresh Water has a pad stuck on it somewhere. Mine are all on one switch on the Control Panel.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 09-28-2014, 09:22 PM   #13
Stormrider151's Avatar
Thanks for all of the information folks. I've bought several RV's from this dealership and I guess they figure I should know all of this but every one of the trailers I have bought have been different in one way or another. I should ask more questions.
Stormrider151 is offline   Reply With Quote
