Old 07-19-2015, 11:01 AM   #1
raceman005's Avatar
Brake cable
Accidently pulled the plug on the breakaway cable while unhooking from camper. I plugged it back in. Hooked back up to the trailer and pulled forward and backed,wheels moved, no noises coming from wheels. Is it safe to say I'll be ok?
raceman005 is offline   Reply With Quote
Old 07-20-2015, 03:59 AM   #2
amxpress's Avatar
Been there, done that. If you reinserted the pin and your brakes are free, you should be good to go.
2013 Palomino Columbus 320RS
2007 Dodge RAM 2500 6.7 Cummins
Reese 15K manual slider
Prodigy
M.I.L. in Florida for good!!
amxpress is offline   Reply With Quote
Old 07-20-2015, 04:04 AM   #3
wmtire's Avatar
If you reinserted the pin fairly quickly, then it shouldn't have hurt a thing. In fact, you are actually supposed to very briefly remove the pin to test the breakaway from time to time. Sounds to me like that's just what you did.
The only problem you may encounter, is many brake controllers have a warning to make sure you disconnect the trailers 7 pin connector from the tow vehicle before pulling the pin on the breakaway switch for testing purposes, as the backfeed from the emergency breakaway switch may damage the controller.
http://www.forestriverforums.com/for...tml#post381053
2011 Flagstaff 831 RLBSS
Old 07-20-2015, 06:24 AM   #4
After reading the post (New Trailer-Fried Emergency Box) I think the BEST advice to give Members is NOT buy a Brake Control Device That could be Damaged by (Pulling/Checking) the Pin of the break away switch while still (Hooked up to the TV)! Many/Many Members have for whatever reason have (Caught/Snagged/Pulled) that (Safety cable) at one time! So I would (NEVER) own a Controller that became Damaged because of it! Most Newer Trucks that are (Ordered for Towing) now have (Built In) Trailer Brake Controllers! Youroo!!
brakes
