Old 11-28-2015, 11:19 AM   #1
Golfnbike13's Avatar
Brake cable hookup
Where is the best place to attach the trailer brake cable to the TV? I'm not sure this is right Click image for larger version
Golfnbike13 is offline   Reply With Quote
Old 11-28-2015, 11:43 AM   #2
That's what I do.
2011 Traverse LT, 3.6L, FWD
Old 11-28-2015, 11:53 AM   #3
Kenny kustom's Avatar
Brake cable hookup
I use a ring to attach it to the hitch.
Not with the chain.
If the chain comes off, so will the cable.
2017 Dynamax Isata 4
Old 11-28-2015, 11:56 AM   #4
Brake cable hookup
Not with the chain.
Name:	ImageUploadedByForest River Forums1448733356.955119.jpg
Old 11-28-2015, 12:15 PM   #5
Ford Idaho's Avatar
I would use a good carabiner in one of the safety chain holes.
Old 11-28-2015, 01:14 PM   #6
Night Stone's Avatar
Same place where you have it, TV's hitch and not chains, like the others above stated. Although I use aftermarket replacement trailer brake cable instead of the original piece. This reduces the slack of the plain wired one, mine was just too long and my fear of it getting caught on road debris and pulling the pin out. Here is a picture of it.
98 Chevy Silverado C3500 crewcab, 454 cu in & 2013 Salem Cruise-Lite 181BHXL
FRF and FROG member
Days camped in 2012 (3), 2013 (3), 2014 (6)
Days camped in 2015, 0 Days so far (0)
This Space for Rent
Night Stone is offline   Reply With Quote
Old 11-28-2015, 01:17 PM   #7
Where are most putting the cable on a fifth?
I punched a small hole in the slider handle, to clip to.
Old 11-28-2015, 01:25 PM   #8
Ford Idaho's Avatar
I put mine over the jaw release handle.
Old 11-28-2015, 01:33 PM   #9
GLCM Warrior
Lefty59's Avatar
My B&W hitch had a centered hole on the back 'rail' that I used to attach a 6" eye bolt into. I had to bend the eye bolt slightly to tilt it away from the hitch enough that I can attach the carabiner. It's a stretch sometimes to reach it, but it works real well.
2014 Wildcat 312QBX
2014 Ford F350 SD 4X4 CC LB 6.7L PSD
Bob & Debbie, USAF Retired
Lefty59 is offline   Reply With Quote
Old 11-28-2015, 02:28 PM   #10
Campfire Master
When I had a TT, I removed one of the license plate screws and replaced it with a stainless eye bolt. On the backside of the eye bolt, I put a washer and nut for strength.
John
AVid is offline   Reply With Quote
brakes
