Old 10-06-2019, 09:36 AM   #1
Bypass pump in Salem 27REI
Does anyone know where to look for the bypass pump on this unit?
Jtmavs is offline   Reply With Quote
Old 10-06-2019, 10:24 AM   #2
What are you trying to do? Are you trying to winterize?
If so, youre looking for two things and not one. You need to find the bypass valves. These are usually right behind your water heater. Then you need to find your water pump which is usually above the fresh water tank. If you cant find it, you may want to turn on so you can hear it.
Lots of threads here that will walk you through the whole process.
Hope that helps.
Skip12 is offline   Reply With Quote
bypass, pump, salem
