Old 01-13-2008, 03:48 PM   #1
Can I walk/crawl on my roof??
Hi everyone,
I really new to RV'ing and am dealing with my first trailer....its a 26 foot Salem Lite by Forest River.........I was clearing some debris off the roof a few weeks ago and I contemplated actually walking on the roof to do this as it would have been much easier than from the ladder leaning on the trailer.........anyways I put one foot on the roof and it didn't feel solid......felt kinda soft.....not like a soft or damaged area on the roof....just spongy....and I thought if I stand and walk around on it, im surely going to go through it or damage it.........its a vinyl or maybe rubber roof......definately not fibre glass...........so whats under the vinyl/rubber on the roof?.........is it safe to walk on?
Thanks!
hoorders is offline   Reply With Quote
Old 01-13-2008, 03:59 PM   #2
I walk on my Flagstaff ultralite roof all the time to re-seal, clean, and inspect things as necessary. Very sturdy up there and I weigh about 205.
Hokiehall is offline   Reply With Quote
Old 01-13-2008, 04:12 PM   #3
Does your roof have the vinyl/rubber roof?
Old 01-13-2008, 04:20 PM   #4
welshman599's Avatar
Send a message via MSN to welshman599
They are all pretty walkable, but you're right they don't feel too strong. The underdecking is either plywood or particle board. mine is 3/8" but I'm not positive if the 'lite' trailers use a slightly thinner roof decking than that. I usually tread quite lightly, stepping as much as possible on the joists. Wear boat shoes or other shoes with soft rubber soles. (Check for rocks in the tread too... the roof material damages quite easily.)
EPDM Rubber is the standard, but a few FR models have a new vinyl roof.
  • Salem 401-2b; 31" Sony Trinitron and two channels on the antenna.
  • Smokin' hot wife... 2 boys, 25 and 10.
83 sweet sweet days camped in 2008 - not easy in my neck of the woods!
welshman599 is offline   Reply With Quote
Old 01-13-2008, 04:24 PM   #5
How would I know where the joists are?
Old 01-13-2008, 04:27 PM   #6
EPDM Rubber is on mine.
Old 01-13-2008, 04:38 PM   #7
Guesswork and feel mainly. When you walk on one, you'll notice no sponginess there. They're normally at 16" I think. Often if you look closely you'll see where two sheets of plywood join... that is one joist location and there will be another one 1/3 and 2/3 across the sheet.
By the way, you'll find a good link to Alpha Systems (roofing manufacturer) in our links thread http://forestriverforums.com/forums/...read.php?t=992
Old 01-13-2008, 08:00 PM   #8
budfans's Avatar
I walk on mine before I close my slides to sweep any braches or other junk , and yes it is on the soft side
07 285B+ cherokee 5er
02 F350 power stroke c/c
budfans is offline   Reply With Quote
Old 01-14-2008, 04:27 AM   #9
Contact your dealer, they maybe able to get the specs from the manufacture or go on line.
Old 01-14-2008, 10:41 PM   #10
The Jolly Mon
NDJollyMon's Avatar
Send a message via Yahoo to NDJollyMon
Some manufacturers of lightweight trailers say not to walk on them.
Stick to the supporting joists, or lay some plywood down to help spread the weight and you should be fine up there.
Pete (Jolly Mon)
2018 Wildwood Grand Lodge 42 DLTS
-Seasonal Space, Northern MN.
-2017 Sylvan 8522 LZ LES/115 Merc/Sea Legs
NDJollyMon is offline   Reply With Quote
salem
