Old 10-18-2016, 10:07 AM   #11
Bought a dehumidifier at Walmart which we run during day when we are out and about, or at night (doubles as a nice noise maker) and have had no issues. Amazing the volume of water it accumulates in a day's time. Good luck!
Rmmeg4 is offline   Reply With Quote
Old 10-18-2016, 10:18 AM   #12
Condensation inside
Condensation is the result of cooling down air that contains moisture (humid air).
Running the air conditioner removes moisture from the air. That is the dripping condensate you see from your roof.
The longer the air conditioner runs, the more moisture is removed from the inside air and dumped on the ground. However, if you are leaving vents open, you are continually letting in more humid air from the outside. This warm humid air touched the colder surfaces and instantly leaves condensation.
You must seal up your camper by closing your vents.
Remember: the act of cooling down warmer humid air creates condensation. When warmer humid air touches anything colder, it will condense.
325BH is offline   Reply With Quote
Old 10-18-2016, 10:37 AM   #13
jeff
jeff64's Avatar
I have 3 small air circulating fans and an electronic dehumidifier that I run at varying times. It helps
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 10-18-2016, 10:45 AM   #14
Condensation inside
Something else to keep in mind, an undersized (or properly sized) air conditioner will remove humidity better than an oversized air conditioner. This is due to the smaller a/c running longer/more-often.
"To much" a/c is rarely an issue in campers, however I thought I would bring it up.
Letting your a/c continually run, rather than turning it off except when you need it, will help de-humidify.
Old 10-19-2016, 06:56 AM   #15
cpaulsen's Avatar
A good dehumidifier works great!
cpaulsen is offline   Reply With Quote
Old 10-19-2016, 07:53 AM   #16
SeaDog's Avatar
When I worked in the HVAC industry we used to remind folks that "it an air conditioner not a cold air machine" To big an AC cools to fast without removing moisture you get condensation (in a stick house wet sheetrock and mold) to small AC can't keep up with heat generated. Like others have said close vents in summer crack vents in winter just the opposite of what one would think.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
AF&AM of Idaho
Old 11-10-2016, 09:53 PM   #17
exposurecontrol
Well, that was helpful advice. I've never had condensation problems in warm weather but have had problems with water condensing on the inside of windows in cold weather. I have a Hemisphere Lite and the only ceiling vent is in the bathroom. Wonder if that would be enough. Otherwise, I'd have to crack a window open I guess.
2015 Salem Hemisphere
2013 Ford F150; Eco Boost; Super Crew,
Max Tow Pkg
exposurecontrol is offline   Reply With Quote
