Old 08-07-2016, 09:48 PM   #1
Golfnbike13's Avatar
Condensation inside
When running our AC over night in the humid summer we always seem to wake up with condensation on things inside the camper. We have both roof vents open. The only exhaust fan is in the bathroom and can't leave that door open as it blocks the kids bunks.
Anyone else have condensation and how do you eliminate or handle?
Golfnbike13 is offline   Reply With Quote
Old 08-07-2016, 11:00 PM   #2
jawga's Avatar
We had so much when we were in florida i thought the sink was leaking
jawga is offline   Reply With Quote
Old 08-07-2016, 11:08 PM   #3
dea49's Avatar
We shut all roof vents to the outside when camping in humid weather.
dea49 is offline   Reply With Quote
Old 08-14-2016, 08:32 AM   #4
Seachaser186's Avatar
I left the roof vent open by accident and had a condensation issue. Closed it and the issue went away.
Seachaser186 is offline   Reply With Quote
Old 08-14-2016, 08:47 AM   #5
Interesting. I always thought you should have vents open to decrease the condensation. But seems like that's not the case....
Old 08-14-2016, 09:18 AM   #6
Hi,
The open vents allow humid outside air to enter the unit, and the cooler interior, somewhat less humid, environment promotes condensation.
FWIW.
Ric Phillips
Rich Phillips
2009 K-2500 Duramax
2014 Silverback 33RL
richp is offline   Reply With Quote
Old 08-15-2016, 12:29 PM   #7
Head Rambler
The A/C is basically a dehumidifier, so keeping the RV closed as much as possible will allow the A/C to lower the humidity in the unit. Leaving the vents open results in moist outside air migrating into the less humid RV, as eluded to above in a couple of posts.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 08-15-2016, 12:38 PM   #8
waiter21's Avatar
If you have condensation inside, then you have a massive air leak that's allowing warm humid air to get in and the moisture is condensing on the cool surfaces.
It appears your massive air leak is your open vents.
Close the vents and I bet your condensation problem goes away.
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
It won't do MACH 2, but I can get a sandwich and take a pee.
waiter21 is offline   Reply With Quote
Old 08-15-2016, 12:49 PM   #9
VinceU's Avatar
Winter time is the opposite, warm moist air trapped inside will condense on any surface in contact with cold outside surfaces. This is when you need to vent.
Old 08-15-2016, 12:52 PM   #10
Flybob's Avatar
Cold outside vents open to prevent condensation
Hot out vents closed to prevent condensation.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
