Old 07-16-2016, 08:10 AM   #161
Golfnbike13's Avatar
Cruise Lite 195BH Owners Thread
I was always under the impression batteries needed to be kept outside or external compartment due to venting of the battery gases ?
Golfnbike13 is offline   Reply With Quote
Old 07-16-2016, 01:09 PM   #162
For better or worse, FR doesn't seal that area very well, there's considerable circulation, especially when moving which is when most of our charging gets done. Considered putting in a small fan to ventilate when charging, but in the end figured it wasn't needed. YMMV.
Lefty665 is offline   Reply With Quote
Old 07-16-2016, 03:46 PM   #163
A couple of thoughts on battery gassing, but remember that I am not a flooded lead acid (fla) battery engineer, nor do I pretend to be one on blogs.
Most gassing occurs near the end of a high rate charge when available current exceeds that usable in converting lead sulphate on the plates. The excess turns into heat, which causes its own problems, and electrolysis that generates hydrogen and oxygen.
Modern 3 stage chargers used in our trailers greatly reduce excess current by first reducing rates as batteries reach about 80% of charge, then reducing again to provide a lower voltage low current float at 100% to maintain full charge. That eliminates most of the excess current that would otherwise be diverted into heat and electrolysis. It seems that will greatly reduce, but not eliminate, gassing. Also, the line voltage charger on my trailer includes a fan that will increase circulation in the under bunk compartment where the batteries are. Modern smart chargers are not the crude beasts we had years ago that would cook batteries and generate copious amounts of hydrogen if left to their own devices.
The 12v charging provided by the TV is a different critter and I need to read a little more about it. While I expect it varies from TV to TV, in general the size of the fusing and wiring between TV and TT lets us know the charging current available is limited. Also seems likely there's a diode in line to prevent the trailer batteries from trying to dump all their current back through the cabling to the TV starter motor. That will knock a half volt or so off the voltage available to drive trailer battery charging. As I noted originally, FR did not seal that area particularly well, so TT battery charging from the TV that happens mostly while moving will have some air circulation.
So there you have it, FWIW, my logic for having moderate concerns about gassing with fla batteries and a 195BH.
Old 07-17-2016, 07:59 AM   #164
TN_Cruise_Lite's Avatar
The overflow/drain is a great idea Lefty, definitely doing that one.
TN_Cruise_Lite is offline   Reply With Quote
Old 07-17-2016, 11:21 AM   #165
It takes a little 1/2 inch Pex, a couple of Ls to go from vertical to horizontal, clamps and adapters to go from Pex to shut off valves. I reused the drain valve that was on the pipe already. A small conduit to I beam bracket provided an easy way to attach to the frame.
Then there was the note taped to the frame to keep me from forgetting which pipe was which. Dunno about this getting old stuff.
Glad it was useful.
Old 07-20-2016, 07:57 AM   #166
Did you have to change out your time to go with a 15" tire? Ours has the 14" and id love to upgrade that.
Harveyfamily is offline   Reply With Quote
Old 07-20-2016, 05:48 PM   #167
Our tire size changed from 205/75x14 to 215x75Rx14. Rims are 14"; and did not change. New tires are also 14". Tire diameter went up from 26.1" to 26.7". We like the wider tread width of 8.5", and more than anything else radial and higher quality vs the original bias ply tires.
Why do you want to move to a 15" wheel? A 205x75Rx15 tire would be 27.1" in diameter and have an 8.1" wide tread.
Old 07-21-2016, 10:35 AM   #168
Ahh, I see it now in your picture. I definitely want a wider tire to help with stabilization.
Old 07-21-2016, 12:46 PM   #169
"Stabilization" parked or rolling? If rolling, what's your TV?
Old 07-23-2016, 09:21 AM   #170
Never Stop Exploring
Camp4two's Avatar
Quick Reference Guide
Originally Posted by Camp4two View Post
As this thread continues to grow it will become more time consuming for anyone to find particular topic(s) of interest without scanning through all the posts. We hope this quick reference will help make your task easier.
We plan to update this reference every 6 months or so and add more categories if needed.
Category/Comment #s
Air conditioner/79, 81, 124-130
Awning lights/83-84, 91, 96, 118, 121
BTU inputs/41
Ceiling vents/fans/50-51, 104-105
Double entry steps/33-37
Dual battery tray/boxes/24, 42, 44
Dual propane tanks/42, 44, 48
EZ lube axles/106-107
FR 195BH trailers/26
Generators/solar panels/inverter/73-74, 99-103
LED lights/light bulbs/38, 66-72
Modifications/upgrades/12, 27, 46, 80, 85, 142-145
Refrigerator/87, 89, 108-113, 116, 119-120, 141
Screen door cross bar/52-55
Spare parts/61-62
Stabilizer jacks/12, 81-84, 86, 92, 98, 108-113, 116, 119
Storage/77-78
Thermostat/47, 49
Tires/wheels/2, 16-18, 65
Toilet/60
Trailer issues/1, 9
TV mount/56-57, 116, 118,122-123, 133, 135-136, 139, 140
Water pressure regulator/29-31
Water tanks/32, 39, 63-64, 115, 117
Weight distribution hitch/sway/7-8, 10-11, 13-14, 19, 28, 43, 45, 92
Every few weeks I'll re-post this reference. Covers most comments from #1-145. I will update it every 6 months or so. Happy camping everyone.
2016 Cruise Lite 195BH
2002 GMC Yukon SLT 4X4
ST205/75/R15/D trailer tires
Camp4two is offline   Reply With Quote
