Old 07-31-2016, 10:13 AM   #181
Never Stop Exploring
Camp4two's Avatar
Great privacy curtain and sliding door mods. Your sliding door is done so nice it looks like it came from the factory that way. When I can get to it, I'm going to follow your lead. Will make our sliding door a little wider. Access to our spare tire would be so easy for tire pressure checks/filling and getting to our camp chairs & stuff. We would seldom remove the spare but if needed can always lift the bed.
Our best mods have been a 4 inch firm memory foam mattress, dual propane tanks, a TV mount and a catalytic converter mounted on the cabinet panel left of the refrigerator.
Thanks again for sharing all your pics!
2016 Cruise Lite 195BH
2002 GMC Yukon SLT 4X4
Fastway WDH
ST205/75/R15/D trailer tires
Camp4two is offline   Reply With Quote
Old 07-31-2016, 02:33 PM   #182
Golfnbike13's Avatar
Rtidwell, like the stereo addition. Are those cabinet panels strong enough to hold the stereo and speakers, or did you put something behind them to strengthen?
Golfnbike13 is offline   Reply With Quote
Old 07-31-2016, 05:35 PM   #183
rtidwell's Avatar
I didn't put anything behind the speakers except for some foam baffles. The speakers seem to be very stable.
rtidwell is offline   Reply With Quote
Old 08-01-2016, 05:55 PM   #184
Originally Posted by Lefty665 View Post
"Stabilization" parked or rolling? If rolling, what's your TV?
For when it's parked.
Harveyfamily is offline   Reply With Quote
Old 08-01-2016, 09:55 PM   #185
rtidwell's Avatar
Cruise Lite 195BH Owners Thread
Camp4two- is there a way to move the subject guide that you made to the top of the discussion?
Thank you for doing that. It's very useful.
Rtidwell
Old 08-02-2016, 02:34 AM   #186
Camp4two's Avatar
Quick Reference Guide
Originally Posted by Camp4two View Post
As this thread continues to grow it will become more time consuming for anyone to find particular topic(s) of interest without scanning through all the posts. We hope this quick reference will help make your task easier.
We plan to update this reference every 6 months or so and add more categories if needed.
Category/Comment #s
Air conditioner/79, 81, 124-130
Awning lights/83-84, 91, 96, 118, 121
BTU inputs/41
Ceiling vents/fans/50-51, 104-105
Double entry steps/33-37
Dual battery tray/boxes/24, 42, 44
Dual propane tanks/42, 44, 48
EZ lube axles/106-107
FR 195BH trailers/26
Generators/solar panels/inverter/73-74, 99-103
LED lights/light bulbs/38, 66-72
Modifications/upgrades/12, 27, 46, 80, 85, 142-145
Refrigerator/87, 89, 108-113, 116, 119-120, 141
Screen door cross bar/52-55
Spare parts/61-62
Stabilizer jacks/12, 81-84, 86, 92, 98, 108-113, 116, 119
Storage/77-78
Thermostat/47, 49
Tires/wheels/2, 16-18, 65
Toilet/60
Trailer issues/1, 9
TV mount/56-57, 116, 118,122-123, 133, 135-136, 139, 140
Water pressure regulator/29-31
Water tanks/32, 39, 63-64, 115, 117
Weight distribution hitch/sway/7-8, 10-11, 13-14, 19, 28, 43, 45, 92
__________________________________________________ ____________________
rtidwell: Every few weeks I will bring this quick reference to the top and update/add categories about every 6 months. Glad you like. Here you go.
Fastway WDH
Old 08-02-2016, 01:52 PM   #187
rtidwell's Avatar
Has anyone found a good way to put access doors on the sides of the dinette bunks?
Old 08-07-2016, 12:54 PM   #188
rtidwell's Avatar
Where does everyone put your level when setting up?
Old 08-07-2016, 01:26 PM   #189
I added externally mounted levels to the frame. I put one on the frame just below the front of the trailer on the driver's side so that I can step out and see it and then know if I need to drive up on some leveling blocks or not and then I put another on the side frame between the door of the trailer and the front so that I can turn and see when level as I am cranking the tongue jack. I tested a number of places to get my trailer level before adding the external level. I tested several places on the kitchen counter and several places on the floor. None showed the same, but all were pretty close. I also checked several places on the frame under the trailer. Again, it was difficult to find something that made me know the trailer was truly level as everywhere gave just a little different reading. I just picked something and went with it.
The reason I added the levels to the frame was that I did not like the stick on kind as they seemed to move around some. Also, I just did not want four more screw holes in the side of the trailer to have to reseal every so often. I just used some small self taping screws.
AS Rabbit
2016 Wildwood 195BH
2009 Silverado 1500
Asrabbit is offline   Reply With Quote
Old 08-07-2016, 01:45 PM   #190
rtidwell's Avatar
I usually just use a 4" level on the floor in front of the door. It just doesn't "look" or "feel" level like that, though.
