Old 08-20-2016, 03:19 PM   #211
Golfnbike13's Avatar
Originally Posted by Camp4two View Post
My 2016 came with ST205/75/R15 Load Range D Tow Max tires. Over 5K miles on them so far with no problems.
They must have changed from a 14" wheel to a 15" with the newer models. My 2014 came with 205/75R14. Probably had 5,000 on the stock tires and just replaced them due to bad uneven wear and some cracking. Maybe next time I'll just switch to 15" wheels for more heavy duty tire.
What brand tire did your 2016 come with?
Golfnbike13 is offline   Reply With Quote
Old 08-20-2016, 04:20 PM   #212
Never Stop Exploring
Camp4two's Avatar
My brand is Power King Towmax STR.
My Load D (8 ply) tires are rated 2150 lbs. @65 psi. I keep them cold inflated at 64 psi. There are both good and bad reviews on this tire. I have been very happy with them so far, plenty of tread left after 5K miles. Minimum 8 ply tires is something to consider if you plan to change to 15" wheels.
2016 CL 195BH
2014 F150 Lariat 4X4 EB
Camp4two is offline   Reply With Quote
Old 08-21-2016, 07:17 AM   #213
Mine came with Ridgway. So far so good.
AS Rabbit
2016 Wildwood 195BH
2009 Silverado 1500
Asrabbit is offline   Reply With Quote
Old 08-25-2016, 11:06 AM   #214
Cruise Lite 195BH Owners Thread
Originally Posted by TN_Cruise_Lite View Post
Lag screwed to the wall stud.
Is that an actual stud on yours? Went to mount mine and it's just a thin piece of wood there to frame the door space. It's maybe 1" thick. Looks like Lag bolts would go through it, most likely splintering, and into the cabinet. I can't seem to find anything in my opening that looks safe to bolt a TV mount into.
Old 08-25-2016, 01:53 PM   #215
TN_Cruise_Lite's Avatar
I pre-drilled and lagged it here.
2018 Coleman Light 1805RB
2010 Chevy Silverado 4x4
2013 Salem Cruise Lite 195BH (traded)
TN_Cruise_Lite is offline   Reply With Quote
Old 08-25-2016, 09:04 PM   #216
A little more artwork ...the red arrows show the thickness of the stud. With the paneling/cabinet brace on the inside and the metal door frame on the outside you basically have a laminated wall stud. The TV and mount probably weighs 5 lbs at most so I have no problem at all having it there but I understand your concern.
Old 08-25-2016, 11:23 PM   #217
Thanks, I was looking at that wood strip on the very edge of your yellow arrow tip. This weekend I'll give it another run and go for the yellow box area.
Where did you run your power and cable cords?
Old 08-25-2016, 11:56 PM   #218
110v goes through where the fridge plugs in on the left. A/V wires go through the cabinet on the right. Going to Warriors Path State Park tomorrow for the weekend I'll get some pics.
Old 08-26-2016, 07:01 AM   #219
The outlet for the fridge on mine is a single outlet so nothing else can be plugged in. Is there any issues with using a power strip there? I can't imagine that small fridge needing its own dedicated outlet.
Old 08-27-2016, 10:02 PM   #220
That's what I did but I plan on changing the outlet after camping season. I can't see that little tv drawing enough amps to overload anything. We've used ours for hours on end without a problem. Been watching football tonight. I've not checked but the exterior outlet right next to the outside fridge door is probably on the same circuit too. We use it for a fan almost all the time here in the sweaty south.
