Old 03-22-2019, 07:55 PM   #1
Cruise Lite (De)Winterizing
Hi all. New to the forum and will be starting our third summer with our 2018 Cruise Lite 197BH. I have been having our dealership winterize and dewinterize our camper, but am interested in possibly doing it myself. It really is pretty cheap for them to do it, but just a pain go drop it off and pick up again.
Are there any instructions on this forum or web specific to the Cruise Lites? It seems every camper has their own quirks and tricks for this.
Also, I've seen using an air compressor and the putting antifreeze in the traps and toilet or draining and pumping antifreeze in the system.
Any help is appreciated. Glad to be here.
NLee is offline   Reply With Quote
Old 03-22-2019, 11:16 PM   #2
bikendan's Avatar
Tons of YouTube videos on this. No Cruise Lite-specific instructions.
Equalizer WDH
Old 03-23-2019, 07:04 AM   #3
Yeah, I've watched a ton. I wish there was one that matched my camper more closely. Or that Forest River had better specific instructions.
Mostly concerned about the hot water heater bypass (I see a valve on each line, but not sure what position they should be in). I also see people taking a water line off the pump to draw the antifreeze into the system.
Old 03-23-2019, 07:43 AM   #4
Not much to do except flush out your water lines and then un-bypass the water heater. If you can post pics of your bypass valves we can help your there. Cruise Lite has used both three valve and two valve setups, possibly even one valve on newer units. I believe there are photos in our library section.
Cedar Creek Lake, Texas
2017 Wildwood 27 RLSS
2016 Ram 5.7L crewcab, 8 speed transmission
CedarCreekWoody is offline   Reply With Quote
Old 03-25-2019, 03:23 PM   #5
Here's a couple pics of the bypass valves, pump, and anode rod.
Is that rod still good for another season?
It doesn't look like they pulled antifreeze in through the pump, so did they just blow the lines out and put antifreeze in the traps and toilet?
ID:	199775Click image for larger version
ID:	199776Click image for larger version
ID:	199777Click image for larger version
Old 03-25-2019, 04:37 PM   #6
It appears the water heater is bypassed. Turn the valves 90 degrees and see if water flows into the heater. The anode looks good for another season.
Old 03-25-2019, 05:12 PM   #7
To flush, hook up to the city water and run water through or fill fresh tank and pump? The pump looks to have pink in it (assuming antifreeze), but can't figure how they hooked into the pump to draw it in. Any thoughts on that?
Old 03-25-2019, 09:01 PM   #8
Put some water in fresh water tank and run the pump to flush it. Hook up to city water to complete the flushing if you wish. Be sure the hot water tank fills with water before you turning it on.
Old 03-26-2019, 06:51 AM   #9
Thanks for your help on all of this. Much appreciated.
Old 03-28-2019, 09:03 AM   #10
bedubya's Avatar
That anode rod is probably good for two or three more seasons.
'17 Toyota Tacoma 4x4 TRD Sport
'17 Salem Cruise Lite 232RBXL
'08 Kawasaki Vulcan Classic 1500
Mickey the Rescue Project Schnauzer
bedubya is offline   Reply With Quote
lite, winter
