In the context of this post, TV refers to "Television" and not "Tow Vehicle."
The "No AM Radio Reception" is a common problem, it seems these RV radios in TT's, Fifth Wheels, etc. are connected to the TV Antenna and as such, are not seeing any AM signal. By the very nature of the TV Antenna system, it will provide little to no coverage of AM broadcast radio.
These radio receivers were intended to be connected to an "automotive" style AM/FM antenna, which would provide the intended AM and FM reception.
That said, the "TV" antenna connection will provide excellent FM performance when the antenna/amplifier is turned on; that performance will be "directional" to an extent, as the antenna is pointed. FM Radio used to lie between old VHF-Low and VHF-High stations; while FM has not moved, TV is fruit loops now with the advent of "Digital." For the sake of simplicity, much of TV lives up in what we used to call UHF-TV land.
Many radios have a switch hidden on the back for, lets call it "Euro" versus "US" frequency standards, if your FM stations work then it is set correctly for FM and AM.
Jeff and Abby
Fur Babies - Xandra Sophia (GSD) and Neo (Min-Pin Mutt who thinks he is a cat)
2015 Tracer Air 235 (previous 1994 Veri-Lite 1130 TC)
1998 Dodge Ram 2500 Quad Cab - 360 - 46RE (Built)
