Old 03-18-2014, 11:13 PM   #1
yourguide's Avatar
Do all RV antennas rotate?
My new 2014 Salem 31BKIS does not appear to have a rotating antenna. Am I missing it somehow or is this correct?
I've yet to get up on the roof to look closer, but is see nothing inside to adjust rotation so far.
yourguide is offline   Reply With Quote
Old 03-19-2014, 01:16 AM   #2
mlangdn's Avatar
Can't speak for the Salem, but on my Catalina, after cranking up the antenna, there is a circle just above the crank that pulls down and can be rotated.
mlangdn is offline   Reply With Quote
Old 03-19-2014, 04:03 AM   #3
Witch Doctor's Avatar
Depends on which antenna you have installed? which one is it?....Some do and some don't. If it's a winguard they do but has to be raised first. Then they also have these 6" mushroom type that do not. Got a picture or model # that might help.
Coachmen M/H
Concord
2018 / 300 DSC
Old 03-19-2014, 07:04 AM   #4
Check to see if it is stuck or hung up in the mechanism. Mine would not rotate after i cranked it up. I believe the dealer found some caulk or gray putty tape stuck to the antenna when they sealed it on the roof.
2013 Salem 30KQBSS TT
Equalizer 4pt Hitch system-12K
2016 Ram 1500 Crew Cab Sport 5.7 Hemi w/8 Speed
Great Laker is offline   Reply With Quote
Old 03-19-2014, 07:43 AM   #5
mjones12's Avatar
You might have one like mine, which is an omnidirectional antenna that is permanently mounted and has wings that ride about 8 or 10 inches above the roof. It can't be cranked up and down or rotated. I have been very pleased with it, by the way. Came from the factory on my 2013 Surveyor.
2018 Coachmen Apex 249 RBS
2010 Silverado LT 5.3 V8
The world is a great book, of which those who never stir from home
read only a page. - St. Augustine
mjones12 is offline   Reply With Quote
Old 03-19-2014, 08:09 AM   #6
If it is an omni-directional antenna, the answer is “no.” If you're not sure what an omni-directional antenna looks like, do a search.
2012 Rockwood 8314BSS
2011 Chevy
Camping, Dutch Oven Cooking, and Homebrewing
campdohbrew is offline   Reply With Quote
Old 03-19-2014, 08:42 AM   #7
yourguide's Avatar
It must be an Omni because I haven't seen any crank inside whatsoever, I'll get a ladder tonight and take a look up there. It looks like it's permanently stuck up so it sounds like it's probably an Omni directional.
thanks everybody!
These are the joys of not buying the RV directly from the dealer I just met a guy in a parking lot and picked it up!
Old 03-19-2014, 12:48 PM   #8
Post a picture of it. If you see aluminum on the antenna, it will be one thatbraises and rotates. If is roundnor oval( most likely whitebplastic) it will not
Sent from my Lenovo P780 using Forest River Forums mobile app
Kuba is offline   Reply With Quote
Old 03-20-2014, 02:02 PM   #9
yourguide's Avatar
Name:	ImageUploadedByForest River Forums1395342038.008183.jpg
ID:	48037 here's what I got without a ladder... I think it's omnidirectional...
Thanks for all the comments.
Old 03-20-2014, 02:22 PM   #10
stevengb's Avatar
Its an omnidirectional....I personally don't have much luck with mine.
Sent from my Nexus 7 using Forest River Forums mobile app
Steve and Michele Bassett
2014 Surveyor Select SV305
2005 Ford F250 Lariat SuperCab 6.0 TurboDiesel
stevengb is offline   Reply With Quote
Old 07-08-2014, 07:09 PM   #11
I was having issues with my omnidirectional but forest river helped me out today. Turns out the cable lines were connected into wrong spots, after switching them around all is good. TV channels and radio are working now.
Kimmers is offline   Reply With Quote
Old 07-11-2014, 02:53 PM   #12
I also have one of those omnidirectional antaneas but I can't get anything on the radio...I would like to get am radio but no luck Although my vehicle sitting right outside can get it perfect. Anyone have any luck with that?
Burgeogull is offline   Reply With Quote
antenna
