Old 05-05-2015, 05:58 PM   #1
Golfnbike13's Avatar
Drip in grey water drain pipe
I've discovered a drip in the elbow joint going into the valve of the grey water drain. What's easiest way to fix? Or do I have to cut out the pvc pipe elbow and replace it?
Name:	ImageUploadedByForest River Forums1430866718.697759.jpg
Golfnbike13 is offline   Reply With Quote
Old 05-05-2015, 06:12 PM   #2
Ford Idaho's Avatar
From what I see I would first remove the 8 screws that hold the valve and remove the valve I would then try to remove the elbow by twisting it while holding the pipe.
It just be loose enough to remove then clean the joints so they can be glued.
Ford Idaho is online now   Reply With Quote
drain, grey water, water
