Old 01-04-2009, 02:51 PM   #1
Electric spaceheater
Does any one know if haveing a space heater pluged in,to keep temps up will hert the converter/ inverter leaving it on full time when not there just keeps things from freezeing?.
hail chaser is offline   Reply With Quote
Old 01-04-2009, 03:42 PM   #2
Head Rambler
First a little lesson. The 'converter' is really a converter/power center. It converts 120vac shore/generator power to 12vdc AND distributes 120v & 12v power to the whole RV as well as changes the battery(s).
An inverter runs off the battery(s) and inverts 12vdc to 120vac to run ac appliances.
Now, as for running a couple of electric heaters, it won't hurt the converter. You will have to be sure not to overload the breakers in the RV.
Gotta go campin!
Old 01-05-2009, 07:28 AM   #3
Thanks for the insite as I am not using this to heat but to keep some warmth in the trailer and keep condensation down.
Old 01-05-2009, 07:13 PM   #4
Wouldn't bare 100W light bulbs accomplish same thing for less risk and less power consumption?
-------> '03 FR Flagstaff 25LB UltraLite
Wolfgang is offline   Reply With Quote
Old 01-07-2009, 09:36 AM   #5
I am using a space heater and the circuit breaker keeps tripping.
georgetown50 is offline   Reply With Quote
Old 01-07-2009, 01:54 PM   #6
CLASS "A" Senior Member
cfsoistman's Avatar
Is this the only thing plugged into the circuit? Is it a straight 1500 watt heater? Does it trip any breakers in your house on any 15 amp circuits? If not it's possible you may have a weak breaker in your motorhome panel.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
salem
