Old 06-28-2016, 07:41 PM   #1
Unhappy Electrical problem.
Help! I am new at this. I have a 2016 Salem 27rkss. Everything worked fine when I parked it in October. I am not getting lights on the inside when hooked to the battery. The slide, awning, jack and stabilizers work. Also, the battery is not charging. I charged the battery and put it back in and still not working. Any advice would be appreciated.
marwood1 is offline   Reply With Quote
Old 06-28-2016, 07:48 PM   #2
fonzie's Avatar
Did you connect the battery properly? Usually it is black positive lead and a white negative lead. If connected in reverse then the reverse polarity fuses in the converter will blow....
Fonzie
Old 06-28-2016, 08:01 PM   #3
Yes, the battery and cables are well labeled. Also, everything work when it is plugged in to electricity.
Old 06-28-2016, 08:15 PM   #4
fonzie's Avatar
OK, then follow positive lead from battery and see underneath trailer near tongue for a mini-breaker and press small black button to reset. Some unit have also a fuse close by that should be checked.....
Fonzie
Old 06-28-2016, 08:20 PM   #5
Flybob's Avatar
Check the two large fuses in the fuse panel ( 30-40A). They could have blown while doing the battery work. If they are bad, the battery will not charge and little things( lights etc) not connected directly to the battery will not work.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 06-28-2016, 08:57 PM   #6
Thank you fonzie! After much looking, I found the reset. (Could they have made it any harder?) Just another quick question. Are the plugs in the trailer supposed to work on just the battery, or does it have to be plugged in? Mine are not working, but everything else it.
Old 06-28-2016, 09:01 PM   #7
wmtire's Avatar
If just on 12 volt DC power (battery) then your air-conditioner, microwave, television, or any 120 volt outlets will not work. You have to have a form of 120 volt AC shore power/generator for these items to work.
This may help
Basic RV Electricity - RV Information (RV Maintenance)
http://rvservices.koa.com/rvinformat...d-amp-draw.asp
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 06-28-2016, 09:02 PM   #8
KDHfan's Avatar
The plugs will not work. Requires shore power/ generator.
2015 Coachmen Apex 288BHS
2014 Toyota Tundra CrewMax 5.7L
KDHfan is offline   Reply With Quote
Old 06-28-2016, 09:09 PM   #9
Thank you all so much for your help. Some of us out here are just lost and really appreciate your experience and knowledge.
Old 06-28-2016, 09:39 PM   #10
Mr. Dan's Avatar
You're not lost as long as you are connected to this forum. Members here have collectively seen everything.
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 28; booked = 34
electric, electrical
