Old 06-09-2015, 03:19 PM   #41
TURBS's Avatar
Originally Posted by Papa GLS View Post
Don't know about yours, but some ovens do not have pilots & must be manually lit every time. Good luck & take advantage of all the knowledge you will find here; they sure have helped me a lot.
Has to have a pilot no?
Never seen a oven without a pilot on a 5th wheel or tt.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "9 nights"
Old 06-09-2015, 03:46 PM   #42
Craigban157's Avatar
Originally Posted by Flybob View Post
If you shut off the propane and do not turn the thermostat down, it may call for heat but will not start as propane is off. If this happens, you need to shut furnace off ( not just down) and give it a few minutes then try again. Usually this will reset it. On the general subject of quality/warranty, I buy from the lowest priced dealer and assume that most if not all issues will not be covered or I am not willing to give up s summer of using my RV waiting for the warranty game so I fix it myself or pay a reliable local RV service center to fix it. Over the years this has resulted in a positive cash balance and experience and little or no downtime.
Thanks for the tip, I will try this.
2015 Salem261 BHXL
2016 GMC Sierra 2500HD
2015 nights camped 90
2016 nights camped so far 120
Craigban157 is offline   Reply With Quote
Old 06-09-2015, 03:51 PM   #43
Originally Posted by cdangel0 View Post
Can you access the back of the furnace to see if the ignition wire is attached?
I don't recall if there is a valve on the furnace that can be turned to allow the flow of propane or not (like the refrigerator), if so, is it on?
There is no outside access to the furnace, only the intake and exhaust. I have to remove the couch to get to the furnace. I don't see any valve, it look like it is piped direct from the propane tanks
2015 Salem261 BHXL
Old 06-09-2015, 03:54 PM   #44
BamaBob's Avatar
Originally Posted by Craigban157 View Post
I did check the fuse, it is good. Just for my FYI if the fuse was bad would the blower still come on?
Probably not...I am just trying to be methodological in figuring out your furnace problems.
I'm with Flyboy, time to check the furnace and make sure something was not switched off or turned off at the factory/dealership.
I would think the igniter would work off the electricity though even if there was no propane flow.
TURBS & OC, ya'll are whizzes at this - any idea?
Nights Camped: 2013 - 24 2014 - 42 2015 - 56 Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 06-09-2015, 03:54 PM   #45
TURBS
2011 32bhok Sabre
Yes, it has a pilot. the oven does not have a sparked like the stovetop, it has to be lit for the oven to work according to the manual.
2015 Salem261 BHXL
Old 06-09-2015, 03:57 PM   #46
TURBS's Avatar
Get the model number from furnace. ....
I know I know behind the couch.
Suburban has a really good diagnostic trouble shooting guide on there website.
TURBS
2011 32bhok Sabre
Old 06-09-2015, 04:00 PM   #47
Originally Posted by lablover View Post
Campers helping campers-I love it. This truly is one big family.
yes it is, not feeling so down about my first RV purchase now after reading this forum, I guess other have as many or bigger problems than I do.
2015 Salem261 BHXL
Old 06-09-2015, 04:12 PM   #48
Furnace will lock out after 3-4 try then you'll have to shut it down and try again. I think you need to work out the air.
Both of these, it sounds like the it starts (the furnace) to light, the blower comes on and blows air across the coupler this causes the relay to let gas come in and calls for spark, so I assume there is something wrong with the back end of the process. No gas being sensed so it fails to spark, then after trying 3-4 times it goes to lock out mode and needs to be reset......
For the stove not lighting you may need to re-adjust the thermocoupler. There have been a few posts relating to this issue lately, some just tweak it and make sure it lines up with the flame. For the pilot light (lighting the pilot) you have to push the knob in to light the pilot, and you light the pilot with a stick lighter.
Hope this helps, we will try and get you going so you dont have to spend so much time at the dealer waiting, consider what I said though and see if the dealer can order parts while you keep the trailer and somewhat enjoy it, obviously the first things you will want to do ASAP (water pump and furnace).
2018 XLR Nitro 36T15
2015 GMC 3500 6.6/Allison
Nights Camped (2017- 16) (2016-13) (2015-13)
SuicideSaints is offline   Reply With Quote
Old 06-09-2015, 04:16 PM   #49
Flybob's Avatar
Have someone outside the Furnace access panel, You should be able to hear the igniter clicking trying to ignite the propane. If no clicking, try the reset procedure.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 06-09-2015, 04:17 PM   #50
wmtire's Avatar
TURBS
Or our library here on FRF. We try to keep a copy of most common things.
Forest River Forums - Downloads
2011 Flagstaff 831 RLBSS
Ive lost my scapegoat.
forest river
