Old 06-09-2015, 06:55 PM   #61
Craigban157's Avatar
Originally Posted by Radio View Post
I do. I carry a heavy extension cord and run it out through a slide seal to the pedestal and run the heater with that. The trailer breakers will handle the heater fine. But they won't handle the heater AND the coffee maker!
ah, another good idea, thanks. Two most important things to me in the morning coffee and heat. We are camped in Maine and it's pretty cool here at night and in the morning.
2015 Salem261 BHXL
2016 GMC Sierra 2500HD
2015 nights camped 90
2016 nights camped so far 120
Craigban157 is offline   Reply With Quote
Old 06-09-2015, 06:59 PM   #62
Flybob's Avatar
The extra cord to the pedestal does not always work. If you have a 30A pedestal, there are generally three of those ganged a little further upstream to another breaker box with 100A breakers. If all thee sites on one 100A breaker use the extra cord to the pedestal trick then the 100A breaker will trip and all three sites will be out.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 06-09-2015, 07:06 PM   #63
Thanks for the tip. The pedestal I'm at has a 50a and 30a, I'm using the 30a for the camper, will the heater with a cord work with that with out tripping everyone off? Can I just plug the heater in the camper wall socket on 30a with any problems?
2015 Salem261 BHXL
Old 06-09-2015, 07:21 PM   #64
schrederman's Avatar
I use a 1500 watt heater just plugged in inside the trailer, usually. I set the t-stat at about 65 so the heater will come on if needed. I haven't noticed it on even once, and we usually camp in winter... albeit usually in southern Oklahoma or Arkansas. It doesn't get that cold down in these parts... usually... I use the stove and make individual cups of coffee, so no coffee maker to worry about. I also use a $90- Oster toaster oven instead of the oven in the camper... with much better results. I do have to remember to turn off the heater to use that.
J & D in Lovely Weatherford, TX
2016 Jayco White Hawk 28DSBH TT
2014 Ram 2500 Crew Cab 4X4 6.7L Cummins
schrederman is offline   Reply With Quote
Old 06-09-2015, 07:21 PM   #65
caper's Avatar
You will not have a problem using the pedestal, it should have 100 amps serving it. If you plug the heater into the camper wall socket you might trip
a breaker in the trailer if you are using an other high amp appliance (coffee maker, toaster or electric kettle.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 06-09-2015, 07:27 PM   #66
caper's Avatar
Call FR and see if the local dealer can fix the pump and pay you for any expenses that you have to pay to get it fixed. Also is there a mobile RV repair company in your area that would repair the trailer under warranty?
Terry and Janet
2007 Ford F150
Old 06-09-2015, 08:10 PM   #67
Cyber Phrenologist
Radio's Avatar
Yes, but....
You have to actively manage your power usage. Turn off the heater before making coffee, provided the coffee maker and heater are both on the same breaker inside the trailer.
Not a big deal. And if you trip a breaker, just reset the thing.
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
Old 06-10-2015, 05:43 AM   #68
DAF44's Avatar
Have you solved the CD playing issue?
If not, I would remove the unit, and check if the factory transport screw was removed by the FR installer. This screw is in the rear of the unit and has a tag attached to it telling the installer to remove it. If it is still there, that's the problem and a very easy fix.
2015 FR Salem 27RLSS
2004 Dodge RAM 2500 Quad Hemi
DAF44 is offline   Reply With Quote
Old 06-10-2015, 06:08 AM   #69
B and B's Avatar
With your oven you now have heat. Set it for 250 and you will be warm. Just crack a window open for a little oxygen. Don't sleep with it on. We camped when I was a kid with out a heater or even a oven. Just a 3 burner cooktop and a flower pot, that was a radiant heater on top of the stove and a propane light like a coleman lantern, never was cold.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
B and B is online now   Reply With Quote
Old 06-10-2015, 06:25 AM   #70
I have not fixed the CD player yet, thanks for the tip. I will check that next.
2015 Salem261 BHXL
forest river
