Old 06-09-2016, 06:38 PM   #11
Max100TN's Avatar
I read where another member gave advice on leveling with a slide. They said that they level with slide side a little higher to start with. Said the slide side lowers some over time. Hope it helps.
A fleeting glimpse of freedom is what we are looking for.
2015 F-250 4x4 6.7 w/ Andersen WDH
Max100TN is offline   Reply With Quote
Old 06-09-2016, 11:22 PM   #12
The stabilizers are only to control the rocking, they don't actually lever your trailer. You will need to do that before putting down the stabilizers front and back. I built leveling blocks from 2"x10" for our cruise lite. Once it's level then put down your stabilizer. You can burn up your motors on your stabilizers trying to use them to level..
If your stabilizers won't move but the motor is turning, there is a pin that locks the motor to the drive shaft. Mine fell out after about the third time I used them. They didn't set the pin. Luckily I heard it hit the bottom plate of my stabilizer. Hope this helps!
Jasdow77 is offline   Reply With Quote
Old 06-09-2016, 11:25 PM   #13
How I leveled my trailer... You can buy sets or make your own...
Jason
2000 Ford F-250 V10
2017 Salem Cruise Lite 273QBXL
2016= 5 Nights Camped
Old 06-10-2016, 10:22 AM   #14
Originally Posted by Ray102382 View Post
With leveling blocks to offset where the level was off, when the front and rear bars come down its off on the side with the slide out. So normally I've added the leveling block to make it level. But with them not functioning I couldn't even do that.
Are you leveling with blocks under the tires?
You do not use the stabilizers to level. You should be blocking up the tires then running the stabilizers down, after you level, to "stabilize" the trailer. The stabilizers are not designed to hold the weight or lift the trailer in any other application other than snugging to the ground to stop the trailer from rocking and shimmy-ing around. They are not designed to lift the trailer in any capacity.
2015 Forest River EVO 2850
2012 Dodge Ram 2500 6.7 Cummins
Yamaha 2k x 2 with parallel cable
EMS 30 PI portable w/ Edison plug
Nights Camped (2016-13) (2015-13)
SuicideSaints is offline   Reply With Quote
Old 06-10-2016, 11:37 AM   #15
Was not aware of that, when I did my walk thru at pick up that's what they told me to use to level it. So good thing I'm on this forum learning! So once I back into a spot and its not level would I then stayed hitched to place leveling blocks under the wheels? Or whats the best process to properly level it?
Ray102382 is offline   Reply With Quote
Old 06-10-2016, 11:51 AM   #16
I go RV'ing not Camping
jgourlie's Avatar
This may be the reason your stablizers have not been working as well as they aren't meant to carry the load and the motors may be strained. This may correct itself or it may be worthwhile getting them replaced under warranty and then following the below procedure for leveling going forward.
Yes you would stay hooked up, back into the spot and get out your level.
If the side of your trailer with the slide is a half bubble high, I would stop right there and unhook.
If it isn't I would pull the trailer forward and put some blocks under the tires and then back up the trailer onto the blocks. Stop check the level again, if it looks good unhook the trailer.
The maximum times I have had to pull a trailer forward to put blocks under the tires is twice to get it level.
You will get the hang of it after a few times!
312QBUD Owners Thread
2015 Wildwood Heritage Glen 312QBUD
2000 Chev 2500 Extended Cab 6 Liter
1400lbs Equal-i-zer Hitch
jgourlie is offline   Reply With Quote
Old 06-10-2016, 12:38 PM   #17
I will have to try this next trip out on 4th of July. Thanks for the help, I had to create a check list to remember all the processes.
Old 06-20-2016, 09:17 AM   #18
http://youtu.be/b4JQV15VzBc
Buffalo2VA is offline   Reply With Quote
Old 06-20-2016, 09:17 AM   #19
I have these levelers and love them super easy to use
Old 07-11-2016, 01:11 AM   #20
We are also looking to purchase this trailer. It's good to hear that you like it and about some of the kinks you are working out in the beginning. Happy camping and a fun time with your new trailer.
LCowan is offline   Reply With Quote
