And use one of these
You can buy an attachment for your hose that injects water inside the heater and and direct the crud out the plug.
Your heater at home has a drain on the bottom to remove the crud but the RV tank is not on the bottom, it leaves a bit of water in it when you remove the plug.
https://www.etrailer.com/Accessories...waAhNMEALw_wcB
2018 Rockwood 2509S Mini Lite
Past: 1984 Road Ranger 20', 1988 Kit Companion
1984 Starcraft 24 foot popup
TV: 1999 Dodge 2500 Cummins 4x4
Honda EU2200i Generator, 300 Watts Solar
Ham Callsign KD7UM
