Old 11-20-2014, 12:52 PM   #11
Originally Posted by Mikegjax View Post
The drain is at the bottom of the tank. My drain did get plugged once with construction debris and I used compressed air back through the line to clear it. It is a small hose and does not drain very fast.
If you pump is not picking up any water it may have lost it's prime or there is not enough water in the tank. Check you quantity indicators to see if it is showing anything.
Does you system have the winterizing valve?
Not sure what you mean by winterizing valve.
Sandy and Steve
Chooie, Baby, Grizzly, Sophie the 4 fur babies
2018 Rockwood 8301WS fiver
2003 Ford F-250 super duty diesel
Vinemont, AL
Triple SS is online now   Reply With Quote
Old 11-20-2014, 03:33 PM   #12
Mikegjax's Avatar
It is a manual valve ( if installed) near your water pump. The valve has 2 positions, normal and winterize. There is also a coiled hose that can be placed in a container of RV antifreeze. With the valve in winterize and the hose in the container, the water pump will pump the fluid throughout
the system. You would want to bypass your hot water heater and remove the water filter prior to doing this. Also open all faucets and low points to purge the system.
All of the above is mute if you don't have the system in stalled in your RV.
Hope this helps.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 11-20-2014, 04:22 PM   #13
I do not recall seeing anything like that at the pump but sounds like something we need. Thanks for explaining
Sandy and Steve
Vinemont, AL
Old 11-20-2014, 04:28 PM   #14
The freshwater drain on ours is on the side of the tank close to the bottom. It is a white plastic petcock which turn 180d to drain.
Old 11-20-2014, 05:44 PM   #15
Flybob's Avatar
You said you pumped 3 gals in the TT after finding your original error. It sounds like you did not bypass the hot water heater. At 6 gals, if you did not bypass it, you have a lot more pink stuff and water in the HW heater. Search here for some help on winterizing your TT.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 11-20-2014, 06:51 PM   #16
If your model doesn't have the winterization valve on the water pump intake (mine didn't), then get a scrap 3-foot length of hose, then losen the hose on the water pump, pull it off, and temporarily add the 3-foot hose.
But as said above, if you didn't set the bypass valve(s) on the water heater, you probably didn't winterize anything. Should take about 2 gallons.
2008 FR Salem 26TBUD
2010 FR R-Pod 171 (2009-2015)
2010 Chevy Suburban
Honda EU3000is inverter-generator
techntrek is offline   Reply With Quote
Old 11-20-2014, 06:58 PM   #17
As you can tell we are really new at this TT thing and are learning and hopefully fast without any real problems or major screw-ups. We did have pink stuff coming from all faucets and in toilet when we quit. I am just hoping that pink stuff and water has either not froze in fresh tank or that it has all drained out. Either way would be ok with me. We also put 1 cup down each drain which was 4 drains and 2 cups in toilet.
I appreciate all the feed back and will try to remember to let everyone know what happens come spring. I am more than ready to start the camping season. We may have to camp close to home but at least we will not be at a stationery home.
Sandy and Steve
Vinemont, AL
drain, fresh water, water
