Old 07-29-2019, 12:40 PM   #1
Marshmallow Expert
MSgt Rick's Avatar
Fresh water drain wonky?
I have had trouble draining my fresh water tank, so I decided to investigate and found what you see in the picture. Iím no engineer, but water typically flows downhill. I guess if the tank was full enough the weight of the water would push it over the hump, but mine only has a few gallons and isnít going anywhere. The tank is located inside on the floor under the bed, not in the undercarriage, BTW.
Was mine put together by a rookie, made on a Monday by an employee with a hangover, or is there a genuine reason it was made this way?
Rick & Stephanie
2019 Toyota Tundra Crewmax TRD Sport
2018 Salem Cruise Lite 241QBXL
Whenever I feel blue, I start breathing again.
MSgt Rick is offline   Reply With Quote
Old 07-29-2019, 12:47 PM   #2
We sure the one circled is the drain? Have a drain, supply, and pump feed line. sure which is which?
gbaldwin is offline   Reply With Quote
Old 07-29-2019, 12:51 PM   #3
hack522's Avatar
What is the line to the left for? I see the inlet fill line but why is there three lines?
hack522 is offline   Reply With Quote
Old 07-29-2019, 12:51 PM   #4
Wait... what?!
I have no clue why it is plumbed that way.
Also looks like your pump suction line is kinked 1/2 shut too!
You sure you have them identified properly? It wouldn't matter about the rise in the plumbing if that one goes to the pump
Days Camped: '16=46 '17=30 '18=51 '19=50
Old 07-29-2019, 01:03 PM   #5
Marshmallow Expert
MSgt Rick's Avatar
100% sure
The line circled is definitely the drain, I had my wife jiggle it inside while I looked underneath and watched the drain valve move up and down. The hose closest to the front of the pic is the feed line to the pump, and the line above the circled drain hose is the vent.
Rick & Stephanie
Old 07-29-2019, 01:05 PM   #6
I certainly can't see any logical reason.
Also can't see any reason why it couldn't be straightened in order to more fully drain tank.
It will take a Psychic to figure out what was going through the mind of the installer. I could see the right angles if the hose(s) were horizontal and the installer was trying to get around a structural component but this?
One note, if the tank was full and you opened the drain this whatever it is would siphon the water out of the tank only stopping when water got to the level of the inlet and air broke the siphon effect. But WHY???
Sami. my Shih-Tsu "Co-Pilot" R.I.P
Politically Incorrect since 1943
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 07-29-2019, 01:07 PM   #7
Wait... what?!
No big deal as long as it will flow 3-3.5 gallons per minute. That's about max for a pump but it does indicate that whoever plumbed this was "challenged".
2004 Nissan Titan
Old 07-29-2019, 01:12 PM   #8
Agreed... but I've see a good pump suck a 1/2 kinked line completely shut.
May as well fix that while you're fixing.
Old 07-29-2019, 01:12 PM   #9
clr
Well since water with not of its own accord flow uphill, you will have to replumb the drain line here. But you will have to remove all of the complicated plumbing that the factory installer put in place to accomplish this. Just run the line straight out and then down a rather simple fix. But you have to wonder what this person was smoking when they did this.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
clr is offline   Reply With Quote
Old 07-29-2019, 01:30 PM   #10
Maybe his foot was in the way and he just plumbed around it.
2004 Nissan Titan
Old 07-29-2019, 01:42 PM   #11
If thats the drain, I think it is impossible to drain. Other than pumping it into the grey or black tank via pump and faucet.
Old 07-29-2019, 01:58 PM   #12
It would not be impossible if the tank were full. If you start the drain when the tank is full, it should fill the top of the drain line and then create a siphon and drain the tank down until the drain connection becomes uncovered; it will then suck air and the siphon will be lost. In other words, it would drain the tank similarly to what many people's vent lines do when they are not routed correctly.
Any subsequent attempt to drain with the tank level below the top of the drain line would "probably" not work, depending on the amount of air/water remaining in the drain line.
2011 Traverse LT, 3.6L, FWD
Old 07-29-2019, 02:03 PM   #13
Marshmallow Expert
MSgt Rick's Avatar
Haha, I do believe you have come up with the only plausible reason!
The kink in the feed tube actually looks worse in the picture, so no worries on that.
I just fixed the shattered roof vents and installed MaxxAir covers last weekend and was disappointed that I had nothing else to fix. Now I can re plumb the drain this weekend. Yay!!!
I better stock up on on repairman fluid (beer)
Rick & Stephanie
Old 07-29-2019, 02:11 PM   #14
I conceed.... if draining a full tank (which I can not remember ever attempting.)
Old 07-29-2019, 02:13 PM   #15
I do it every spring when I chlorinate my tank. Don't you?
Old 07-29-2019, 02:21 PM   #16
Would have to really think about my chlorinating procedure with that drain. Quite a bit left in the bottom of that tank even in best case scenerio.
Old 07-29-2019, 02:22 PM   #17
Again... not if you started the siphoning/draining when the tank was full.
Old 07-29-2019, 02:42 PM   #18
ok
Old 07-29-2019, 03:51 PM   #19
Reuse one of the 90-degree elbows
Yup. Just re-use one of the 90-degree elbows, right where it goes through the floor.
Larry
Larry-NC is offline   Reply With Quote
Old 07-29-2019, 04:13 PM   #20
RV There Yet?
IsleDog's Avatar
I think this installer is a whole lot smarter than we are giving them credit for. they are teaching us a valuable lesson in physics using Pythagorean's Cup.
2018 17RP
2009 Crew Cab King Ranch F150 "Goose"
IsleDog is offline   Reply With Quote
drain, fresh water, water
