Old 10-11-2015, 08:12 AM   #1
Fresh water tank and pump
I have a 2014 Hemisphere 356qbq and never have used the water tank. Does anybody know where those are located?
Duck8792 is offline   Reply With Quote
Old 10-11-2015, 09:06 AM   #2
Georgia Frog Rally 2018
aceinspp's Avatar
Not familiar with this unit but you should see a sticker on the side of your unit maybe next to or close to city water hook up that says fresh water fill. You also will have to find the water pump as there is an inline valve to turn so it will draw the water from the tank. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
Old 10-14-2015, 03:47 PM   #3
Boss Ox & Drovergirl
oxcamper's Avatar
On our Hemi 282, water tank inlet is next to the city water inlet marked, as aceinspp says, "Fresh Water Fill". There is no gravity fill, you have to use a hose with pressure.
Our tank is actually on the opposite side of the trailer by the entry door. Look underneath your trailer for the overflow and that should be where your tank is.
They put the water pumps in a variety of places, turn it on and listen for the location. Ours is under the kitchen sink.
Good luck
Mark, Vicki, & Scout THE dog
2015 Hemisphere 282RK
2010 F250 Super Duty
1992 Goldwing Aspencade
oxcamper is offline   Reply With Quote
fresh water, pump, tank, water, water tank
