Old 08-18-2014, 08:09 AM   #1
afg83133's Avatar
Fuse keeps blowing
I have salem hemisphere 366 BH.
I have one fuse that keeps blowing I keep replacing it, it's over table and sofa slide there are three light on that slide.even if I don't turn them on I will see the little red light go on in the fuse box,has anyone else had this problem?
afg83133 is offline   Reply With Quote
Old 08-18-2014, 08:11 AM   #2
afg83133's Avatar
I'm sorry I forgot to say the year of the trailer it's a 2014. A couple of months old and I had this problem since the first day.
Old 08-18-2014, 08:26 AM   #3
bubbles's Avatar
Sounds as though there is a short to ground of the load side (lights) wire from that fuse. It could be intermittent and just about anywhere between fuse and light assemblies and short to ground as the slide goes in/out.
Old 08-18-2014, 08:36 AM   #4
Dave_Monica's Avatar
You should check the 12V wiring under the slide...sounds like that line got caught in the slide drive and is now shorted.
Dave
Old 08-18-2014, 08:45 AM   #5
afg83133's Avatar
I will do that tonight. Thank you
Old 08-25-2014, 06:37 AM   #6
afg83133's Avatar
Here's an update to my fuse blowing, I looked under the slide and followed the wiring. Sure enough it went through the frame to the back slide. Where it went the the frame the wire was chaffed and shorting out. I taped and place a piece a plastic around that area to help protect it. Thank you
fuse
