Old 07-15-2014, 05:16 PM   #1
Generator won't run A/C
So I posted in another topic that I bought a dometic lw3000 plus and it would run my 13500 a/c. Well that was before I tried to run it on a hot day 😓.
On our last trip 4th of July weekend I tried to run ac. the fan would run for about 30 seconds then trip the generator. I saw a video on youtube showing how to run the ac w this generator but still no luck.
Do I need a bigger generator? Or would a hard start capacitor help. I donot see that the ac has one. The TT is a 2014 26tbud.
Nacho is offline   Reply With Quote
Old 07-15-2014, 05:25 PM   #2
fonzie's Avatar
When trying to run your AC, was the water heater and refrigerator on propane? If on electric you probably were exceeding capacity of your generator.
Fonzie
Old 07-15-2014, 05:27 PM   #3
I turned everything off water heater, fridge, I even tried turning off all breakers except the ac
Old 07-15-2014, 05:34 PM   #4
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
1. Do you have a way to check how many Amp the air conditioner draws, looks like the generator can deliver max. 23 Amp at 120 Volts.
2. Make sure nothing else draws electricity and the batteries are fully charged, the converter/charger draws a substantial amount of power until the batteries are full.
3. Don't use extension cords.
Almighty 2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is offline   Reply With Quote
Old 07-15-2014, 05:35 PM   #5
fonzie's Avatar
According to their website, it should be able to power your AC.
(With a clean, stable power for all home or work applications, the LW3000 Plus easily powers a 13,500 BTU air conditioner.)
I have a Yamaha 3000 and it powers my 13.5K AC with ease. Maybe you need to install a hard start capacitor. Others will chime in with more info at what to do next hopefully.
Fonzie
Old 07-15-2014, 05:40 PM   #6
Name:	ImageUploadedByForest River Forums1405463932.695319.jpg
ID:	58252Click image for larger version
Name:	ImageUploadedByForest River Forums1405463956.181635.jpg
ID:	58253Click image for larger version
Name:	ImageUploadedByForest River Forums1405463974.151996.jpg
Not sure if these pics help
Old 07-15-2014, 05:42 PM   #7
I'm guessing your converter/charger is still charging the batteries which can be between ~5 and ~15 Amp AC, when you add the initial draw from the air conditioner of ~15 to ~20 Amp that could be too much.
Try running the generator for at least and hour or so before you start the air conditioner.
Old 07-15-2014, 05:50 PM   #8
Only difference is your Yamaha 3000iseb has the boost option which the OP's doesn't have, that makes it a little trickier.
Old 07-15-2014, 05:52 PM   #9
Herk7769's Avatar
Our Yamaha 3000Sib also has trouble sometimes even when not in ECO depending on outside air temp.
Putting in a time delay module to delay fan start up until after the compressor is on speed solved it.
HAM CALLSIGN - KC3FFW
Old 07-15-2014, 05:53 PM   #10
I will try testing the amps and letting generator run for an hour thanks
generator
