Old 10-28-2015, 01:37 PM   #1
Malacca's Avatar
Grey water tank issue
2015 hemisphere lite 312QBUD
I just bought this second hand. I have no experience with a TT.
I am about to hit the road and am doing a dry run in my driveway. I hooked up water. Everything worked fine. I ran water through the sinks, tub and flushed the toilet. I then went drain the black water. A lot more came out as I only flushed the toilet twice.
I then tried to drain the grey water. Nothing. Nada.
So I ran a LOT more water in the sinks & bath. I leveled the trailer (just in case).
Still zip. Nothing from grey water tank. And I can hear the handle pulling the valve open.
In poking around the web I find out this model may have two grey tanks. I looked for another valve - nothing.
Of course the FR manual that came with it is completely useless.
Help.
Malacca is offline   Reply With Quote
Old 10-28-2015, 02:50 PM   #2
Malacca's Avatar
OK, I do have two grey tanks. The back one is just for the outside kitchen.
Can't find the slide lever for the front tank! Panel shows it 3/4 full.
Anyone know where it is?
Dan
Old 10-28-2015, 03:00 PM   #3
fonzie's Avatar
I don't know your unit but I have seen some units where the handle is in the wheel well??
Fonzie
Old 10-28-2015, 03:27 PM   #4
Malacca's Avatar
Nope. Nothing in the wheel well. I looked under the entire underside and can't see anything.
Old 10-28-2015, 03:39 PM   #5
fonzie's Avatar
Read this thread might help....
Heritage Glen 312 qbud waste tank valves
Fonzie
Old 10-28-2015, 03:44 PM   #6
Malacca's Avatar
Fonzie - I read the post. Thanks. Descriptions are vague. I still can't find the third lever.
Black is left of drain connection. One grey is under bunk slide.
Old 10-28-2015, 03:46 PM   #7
fonzie's Avatar
Well hope someone else will chime in and provide info.....
Fonzie
Old 10-28-2015, 04:06 PM   #8
I have 3 valves in the same location on my 312qbud. There are two valves up on the frame rail directly above a lower hanging valve.
atcbrownie is offline   Reply With Quote
Old 10-28-2015, 04:15 PM   #9
The first pic shows where they are located.
The second pic shows the lower (front) grey tank next to sewer drain.
The third pic you can see the bar for the lower grey with the two other valves directly above.
ID:	93105   Click image for larger version
ID:	93106   Click image for larger version
Old 10-28-2015, 04:32 PM   #10
Malacca's Avatar
I'll post pics once it stops raining. Mine has a sticker for black and one for grey at the outlet. But the second grey lever is 7 feet back. Hmmm....
grey water, tank, water, water tank
