Old 01-29-2015, 11:56 AM   #1
tim mccarver's Avatar
Have a 2015 Salem 27RKSS
We really like it have had since July took to lake every month so far and stayed in it December for 2weeks at home to let family stay in house only problem I have is about every hour to 2hours the water pump comes on for 1to4seconds have looked everywhere can not find a leak I'm new to FR app
tim mccarver is offline   Reply With Quote
Old 01-31-2015, 07:10 PM   #2
Welcome. Even with no leak that can happen as the water in the system cools off and contracts, but usually it only happens 1-2 times. Since yours continued the whole time the next place to look is the overpressure relief valve at the top of the water heater (outside).
2008 FR Salem 26TBUD
2010 FR R-Pod 171 (2009-2015)
2010 Chevy Suburban
Honda EU3000is inverter-generator
techntrek is offline   Reply With Quote
Old 01-31-2015, 10:01 PM   #3
Thanks techntrek I will check the water heater
Old 02-02-2015, 08:44 AM   #4
Boss Ox & Drovergirl
oxcamper's Avatar
You may have an air bubble somewhere that is acting like a surge compressor, You can just keep the pump turned off when you're not using it.
Mark, Vicki, & Scout THE dog
2015 Hemisphere 282RK
2010 F250 Super Duty
1992 Goldwing Aspencade
oxcamper is offline   Reply With Quote
Old 02-08-2015, 04:23 PM   #5
If you don't have water seeping out somewhere inside or dripping outside you have leakage at the pump or check valve back into the water tank. You can turn off the pump when not needed and have your dealer fix it after your done camping or can let them work on it.
marc.williams is offline   Reply With Quote
Old 02-09-2015, 12:01 AM   #6
Thanks a lot for info I have left pump on and can not find any leaks inside or out when I get time I will call dealer to set up a time to have it worked on between my work and everyone in family getting this flu that's going around its hard to find the time to work on camper right now
Old 03-01-2015, 11:33 AM   #7
OK I have called the dealer have a appointment set for April was earliest I could get it in I told them what it is doing they said they could fix it take them about an hour
Old 03-13-2015, 06:14 PM   #8
Dealer called got camper in early they found a fitting that was lose was not leaking water but was causing the pump to cycle. Now I'm getting it ready to go on a camping trip far 14 days on Lake DeGray
Old 03-14-2015, 10:40 AM   #9
oxcamper's Avatar
Hoorahh! Good to Go. We get a lot of dealer bashing but it's also really good to give them credit for doing a good job too.
salem
