Old 10-16-2017, 02:29 PM   #1
HDTV antenna on Salem 201BH
Hi there. New to the forum and loving my new trailer. I have a 201BH that on the rear of the unit are coax inputs for satellite and cable. I assume that I do not have an HDTV antenna then? On the inside of the unit there is no unit on the ceiling to raise or aim. Can someone confirm?
emjayuu is offline   Reply With Quote
Old 10-16-2017, 03:16 PM   #2
Moderators' Assistant
bikendan's Avatar
HDTV antennas are a well known marketing scam.
You can get a HD tv signal with rabbit ears antenna.
It's the tv that has to be HD, NOT the antenna.
We've been able to get HD tv with our regular Wineguard batwing antenna. Even on our old 2007 HTT's batwing.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 10-16-2017, 03:32 PM   #3
Are you sure that no antenna was installed on your roof? It could be a bat wing style or a fixed non crank. Having a coax input for cable doesn't mean no antenna was installed. Take a picture of your roof.
DYNAMAX 2016 FORCE HD
houstonstroker is offline   Reply With Quote
Old 10-16-2017, 08:28 PM   #4
Thanks. I will take a look. It may be that there just wasnít a signal where I was. Not sure.
Old 10-16-2017, 08:31 PM   #5
Pics of the antenna on the roof. Click image for larger version
Old 10-16-2017, 08:57 PM   #6
Decon Blue's Avatar
Looks like you have a fixed batwing antenna.
Retired and loving it. Still looking for that perfect high.
Decon Blue is online now   Reply With Quote
Old 10-16-2017, 08:58 PM   #7
Retired JSO's Avatar
I see the refrigerator roof vent. Your antenna is probably a round disc on a staff about 9Ē tall. You should have an area inside where the tv goes, either bedroom or living room with cable connections for your tv and an antenna booster button.
Retired JSO is offline   Reply With Quote
Old 10-16-2017, 09:06 PM   #8
Decon Blue's Avatar
You can look at the pics and see itís a fixed batwing antenna.
Old 10-16-2017, 09:21 PM   #9
Thats the newer ant from FR..
See this post...
Its a good antenna IMO.. Did you turn on the booster button?
Replace TV antenna
It does not turn and is an omni and directional but its fixed..
If you prefer it 90 degrees the other way you can go on roof and loosen the bolts to turn it..
Lawrosa is offline   Reply With Quote
Old 10-16-2017, 10:36 PM   #10
See this post...
Replace TV antenna
Thanks. I thought I had the booster on but I will try it again.
antenna, salem
