Old 08-23-2016, 08:34 PM   #1
Heater upgrade.
I have a 2016 368rlbhk. The unit came with a 35k btu furnace from the factory that seemed to be insufficient in moderately cold northern WI spring weather. Would swapping out the 35k unit for a 42k btu unit make a significant difference? I plan to add some additional insulation in the basement as well. Maybe even swap the cheap corrugated ducting for hard ducts. But for about $200 after resale of the old furnace I could upgrade to a 42k unit. I am looking forward to your thoughts and insight.
AudiOnly101 is offline   Reply With Quote
Old 08-23-2016, 09:07 PM   #2
TURBS's Avatar
Will it even fit in the same area?
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
2016 nights camped "32"
Old 08-23-2016, 09:12 PM   #3
Same exact dimensions.
Old 08-23-2016, 09:27 PM   #4
Left Coast
Have you felt around the outside of the ducting with furnace running?
Old 08-26-2016, 08:14 AM   #5
Happy Camper
Tonylmiller's Avatar
Talking
I would estimate a 20% improvement. That would be 42/35. Yes, I am a rocket engineer.
2021 Forest River Sabre 37FLL
Towed with 2019 Silverado 2500 HD
B&W Turnover Ball Gooseneck hitch
Anderson Ultimate Connection 5th wheel hitch
Tonylmiller is offline   Reply With Quote
Old 08-26-2016, 08:22 AM   #6
Tony, that was my best guess as well.
Old 08-26-2016, 09:14 AM   #7
Before you go to the trouble, have you made sure all your vents/ducts are fully clear and you're pushing a good amount of air?
There are many threads here of folks complaining they aren't getting heat from their vents. Turns out their vents are twisted or crimped.
2011 Traverse LT, 3.6L, FWD
heater, upgrade
