Old 09-07-2019, 05:36 AM   #1
chuck9997's Avatar
Hemisphere 23rbhl Low Point Drains
I just bought a 2017 Salem Hemisphere 23rbhl. I've located the fresh water drain with open and close valve.. and the fresh water over flow.
Where are the low point drains? On other campers I've owned.. I would see two drains.. usually red and blue.
Any idea where they might be on this model?
2014 Rockwood Premier A-122S
2013 FORD F-150 STX, Super Cab
chuck9997 is offline   Reply With Quote
Old 09-07-2019, 01:19 PM   #2
handymanj56's Avatar
I have the same model and year I'm unaware of any lowpoint drain.. like you said just the freshwater and overflow... Click image for larger version
handymanj56 is offline   Reply With Quote
Old 09-07-2019, 01:39 PM   #3
bikendan's Avatar
Originally Posted by handymanj56 View Post
I have the same model and year I'm unaware of any lowpoint drain.. like you said just the freshwater and overflow... Attachment 214402
Nearly all RVs with cold and hot water lines, have low point drains.
Equalizer WDH
Old 09-07-2019, 04:36 PM   #4
chuck9997's Avatar
I agree... I'm going to do a thorough search. Some folks said they are kinda hidden on other Salem models.
Old 09-08-2019, 02:11 PM   #5
Not underneath
On our 2002 SOB, the low-point drains are actually inside, at the very bottom of a cabinet. You pull out a drawer and turn them from inside. Just little stubs underneath.
Larry
Larry-NC is offline   Reply With Quote
Old 09-08-2019, 02:24 PM   #6
Brother Les's Avatar
should have a red and blue hose next to each other. Mine comes out under the bath room sink.
Brother Les
Old 09-09-2019, 06:26 PM   #7
My 282rk is the same as brother Les.
lewisra is offline   Reply With Quote
Old 09-15-2019, 07:03 PM   #8
I have the same model. The two low point drains are on the slide out side near the back most wheel. You have to get down and look up under the trailer
WhoMe is offline   Reply With Quote
Old 09-24-2019, 12:31 PM   #9
Mine are outside under the shower above the grey and black valves
AceCombat is offline   Reply With Quote
drain, hemisphere
