Old 05-06-2013, 08:38 AM   #1
RV maniac's Avatar
Holding tank question
Hey everybody, just bought a 2014 salem hemisphere 356qbq. This is my first 5er but not my first camper. Just took it out for the first time this weekend and when I pulled up to the dump station and pulled off the cap water went everywhere. I thought my valves were open but they weren't. After I finished emptying my tanks there and pulled forward to empty my back tanks it was the same deal. Anybody ever had this happen? Where did that water come from?!? Thanks for the help everyone.
RV maniac is offline   Reply With Quote
Old 05-06-2013, 08:44 AM   #2
Would guess someone left the valves open with the cap in place and then sometime later closed them. That's why I keep a clear elbow on and cap it so there are no surprises. I even put a stainless screw in so it won't be taken off accidently.
Old 05-06-2013, 08:50 AM   #3
RV maniac's Avatar
I didn't even think to leave the elbow on then put the cap on over it, good idea!
Old 05-06-2013, 08:56 AM   #4
puff's Avatar
Would guess someone left the valves open with the cap in place and then sometime later closed them. That's why I keep a clear elbow on and cap it so there are no surprises. I even put a stainless screw in so it won't be taken off accidentally.
X2
Glen & Robyn (A.K.A. Puff & Crickit) Full Timers..
2006 F350 6.0 with 3.73 gears, 4X4, Extra-Cab Long Box, Oil/Tranny/P.S. Coolers. Coolant filter. SCT Livewire.
2011 Cedar Creek 36RE, Auto levelers + too much to list..!
puff is offline   Reply With Quote
Old 05-07-2013, 07:50 AM   #5
Herk7769's Avatar
Buy one of these and leave it on.
It will prevent wet stinky shoes in the event of:
1) Joker who pulls handle then closes it at rest stop.
2) TP trapped in tank valve when closed and causes slow leak over time.
3) Forgetting to close one on previous dump.
3 " Twist on Waste Valve RV Holding Tank Valve Replacement Valterra T58 | eBay
HAM CALLSIGN - KC3FFW
Old 05-10-2013, 11:51 AM   #6
RV maniac's Avatar
Well I figured out the problem yesterday. There is a third gray tank valve in the middle of both dump gates that the dealership didn't tell me about and of course it was open. It's the gray tank for the kitchen sink. So glad it wasn't a hidden black tank!
Old 05-10-2013, 12:45 PM   #7
Phat Phrog Stunt Crew
awwall's Avatar
However, you may want to still take Lou's advice. I did the same thing he did because of leaks through closed valves. This will let you get your hose on before you open the valves.
Wayne & Susan Biloxi,Ms
2012 GeorgeTown 351DS...2015 Ford Focus/Brake Buddy
FROG Member
awwall is offline   Reply With Quote
Old 05-10-2013, 02:08 PM   #8
Herk7769's Avatar
While I do not recommend doing this with Hosrt Probes (standard Gray water probes stick way out into the tank and can attract paper and debris), the end of line valve has another "undocumented" feature when boondocking.
Since the gray water tank typically fills a lot faster than the black, some RV'ers (typically NASCAR campers) use the end of line valve to transfer gray water to the black water tank. They wait until the gray is full, and with the end valve closed, open the gray tank valve. This dumps gray water into the manifold.
Now open the black water tank valve. The higher level in the gray tank will try to equalize by rushing into the black tank. After a few "potatoes"; Close the black valve. Up to 5-8 gallons of gray water will whoosh into the black tank. If done quickly enough, very little (if any) black water will enter the manifold.
Dump as normal; just remembering the mast is full of gray water to the end of line valve.
Old 06-30-2013, 10:12 PM   #9
Does this mysterious middle gray tank flow into Gray #1 or Gray #2... neither? I had the exact same thing happen to me and I haven't been able to figure out how to get the caps off without getting wet yet... perhaps I'm a little challenged. lol
2014 Salem Hemisphere 356QBQ
2005 F-350 King Ranch 4x4
2006 Yamaha AR230
"If I am unable to make the gods above relent, I shall move Hades." -Virgil (The Aeneid)
Okie Dokey is offline   Reply With Quote
Old 07-01-2013, 08:10 PM   #10
RV maniac's Avatar
Mine flowed into the one that's at the front of my fifth wheel. I have 2 grays and one black in the front and one gray and one black in the back.
Old 07-01-2013, 08:42 PM   #11
The valve on my front grey tank leaked from new, just glad it wasn't the back tank!
Now I just put some clean water down the bathroom sink, enough to fill the dump valve area, then shut that dump valve. At least when I open the cap the only thing that comes out is clean water.
I don't feel like dropping the belly cover and trying to change the valve, as it is probably glued in place.
bakken is offline   Reply With Quote
