Old 05-13-2018, 09:12 AM   #1
Hot water heater Salem Cruiselight 195Bh
I cannot seem to get my hotwater to work on 120 AC. I cannot locate the 120 AC switch on the outside panel or inside the camper. I get great hotwater on propane and have a switch for this inside the camper. Because I have hot water on propane this indicates my bypass valve is in the correct configuration. Please help.
davo4466 is offline   Reply With Quote
Old 05-13-2018, 10:21 AM   #2
fonzie's Avatar
this post should help...
Suburban's electric switch and much more
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 05-13-2018, 10:33 AM   #3
Are you sure you have an electric heater? Many are propane only.
Cedar Creek Lake, Texas
2017 Wildwood 27 RLSS
2016 Ram 5.7L crewcab, 8 speed transmission
CedarCreekWoody is offline   Reply With Quote
Old 05-13-2018, 10:43 AM   #4
wmtire's Avatar
According to the standard features at the Salem link, you only have a DSI (propane) water heater, thus don't have the electric heating element option. You may be chasing a ghost here as CedarCreekWoody pointed out.
As excerpted:
2011 Flagstaff 831 RLBSS
Just imagine, for a moment, if there were no hypothetical situations.
Old 05-13-2018, 10:51 AM   #5
Yes I am slightly embarrassed. It is propane only and checked the specs you gave me. Thanks for the information. I assumed they all had the 120 ac option. I guess not.
Old 05-13-2018, 04:47 PM   #6
For what it's worth I have seen heating elements to add the 120 volt options to heaters that did not come with. I've never installed one.
heater, hot water, light, salem, water, water heater
