Old 06-30-2008, 05:53 AM   #11
We do not have an outside shower and yes I did check the bypass and is is fully closed.
EliteHVAC is offline   Reply With Quote
Old 06-30-2008, 06:38 AM   #12
Head Rambler
This is a puzzler. Have you actually measured how hot the water is coming out of the tank with no cold mixed in? It should be at least 140ºF.
I still am inclined to believe it may be the water heater bypass. There have been cases of them leaking through even though they're closed. There also should be a check valve on the cold water inlet to prevent the hot from backing out of the tank.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 06-30-2008, 03:23 PM   #13
KyDan's Avatar
It might not be dual heat.
I said "IF it was dual" you can get quicker recovery with both on.
You will have a circuit breaker marked water heater
and the water heater has a little rocker switch found hidden in the
outside burner area of the WH if you have electric.
Old 06-30-2008, 08:23 PM   #14
The Jolly Mon
NDJollyMon's Avatar
Send a message via Yahoo to NDJollyMon
My Salem has a 20 gallon electric water heater. I never run out of hot water. :-)
I wonder if the hot water is backing into the cold lines somewhere? Is the cold water cold...or warmish?
Pete (Jolly Mon)
2014 Jayco Whitehawk 24 RBS
2004 Nissan Titan LE, 4x4
Equal-i-zer hitch
NDJollyMon is offline   Reply With Quote
Old 07-01-2008, 11:11 AM   #15
Using the gas we would have to stop the water and lather up so that the hot water would last enough for a single shower. We found out recently that our tank had the electric heat and was shown the small switch hidden on the outside at the hot water tank access. (could not get it to work but a friend found that the cable was out of the breaker)
This past weekend we never used the gas for heating the hot water. On electric, the hot water lasted an entire shower and a second only after a 3-4 minute break before running out.
2008 Rockwood 8317SS - 2010 F150
2013 Camping Days: 22
2012 89 2011 50 2010 61
OregonCamper's Pics click here
OregonCamper is offline   Reply With Quote
