Old 06-05-2011, 10:46 AM   #1
Icebox ?
Fixin to go out on first trip in our fifth wheel. 26ddss. Everything was great at dealer. Got it home sat for a long week now loading it up getting ready to go. Icebox won't come on at all electric or gas. Any ideas what I could be doing wrong. Hope isn't broke already.
GandG is offline   Reply With Quote
Old 06-05-2011, 10:56 AM   #2
sherdep's Avatar
it takes atleast 12 hours before you will feel it get cold enough to put food in it to keep from spoiling.
if you are trying gas - did you purge the air out of the line by running the stove top first?
the fridge works off of the 12 volt side so see if your interior lights work to verify you have electricity inside the camper.
I doubt you threw a breaker - just check those as well to make sure
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 06-05-2011, 11:01 AM   #3
Trying on electric. Everthing else is fine checked breakers. Did what book said to do on getting air out of line. Fired up stove just to see if gas was moving down the line. All lights ac are working just no icebox at all. Been trying since yesterday. Leaving out in morning icebox or not. But would love to use it.
Old 06-05-2011, 11:04 AM   #4
sherdep's Avatar
What Make and Model Icebox do you have?
if it worked at the dealer one would think it would be working now.
does your model have the on off switch with the LED that lights up showing it is on?
