Old 04-11-2015, 07:17 PM   #11
I agree with Timex's post on using the low speed for noise reduction. I have since installed a Luxpro digital on my Windjammer with an spdt switch. I bought the switch from Radio shack and installed it on bottom of my thermostat out of sight but easy to reach with my index finger. Don't bother unless you just want a longer project on the switch.
2014 Windjammer 3025W Diamond 34.5 ft 8300 lbs.
2010 F150 SC XLT 4x4 5.4L, 3.55 gears 20" rims
12 k Equalizer WDH, Firestone Airbags, HD Bilsteins
TST 507RV TPMS
Zolin is offline   Reply With Quote
Old 04-30-2015, 12:43 PM   #12
Golfnbike13's Avatar
Installed this one today but have a question settings. It is a propane only Suburban furnace. Photo below shows the setup options, I only have the ones started. Im confused on the Heat Cycle Rate (CPH: cycles/hour). Can anyone help me select ?
Name:	ImageUploadedByForest River Forums1430415764.562965.jpg
ID:	75722Click image for larger version
Name:	ImageUploadedByForest River Forums1430415783.596449.jpg
ID:	75723Click image for larger version
Name:	ImageUploadedByForest River Forums1430415796.629801.jpg
ID:	75724Click image for larger version
Name:	ImageUploadedByForest River Forums1430415809.212838.jpg
Golfnbike13 is offline   Reply With Quote
Old 04-30-2015, 01:15 PM   #13
Canadian Member
itat's Avatar
Use setting '5' for the heat cycle.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
Old 04-30-2015, 01:39 PM   #14
phillip252's Avatar
I to changed to a digital ts. I have a questions. how many degrees past your heat setting before heater shuts off?
phillip252 is offline   Reply With Quote
Old 04-30-2015, 02:39 PM   #15
Thanks!
Old 04-30-2015, 02:40 PM   #16
I just tested and it shut off after reaching one agree above the set temp.
Old 05-02-2015, 08:09 PM   #17
so I had to use it for a trip this weekend it wasn't shutting off till it got four and 5 past the setting. Plus it was coming on when the temp was above the setting. Any ideas??
Old 05-02-2015, 08:16 PM   #18
markb5900's Avatar
On the back of most thermostats like that there is a small screw for adjusting how close to temp it turns the furnace or ac on and off. It is there so it isn't going on and off every time it changes 1 degree.
Look on the instructions if you still have them and it should show it there.
Mark B
2015 32 Foot Rockwood 8289WS 5th Wheel
2017 GMC 3/4 Ton TV
markb5900 is offline   Reply With Quote
Old 05-02-2015, 08:42 PM   #19
Flybob's Avatar
You need to check manual. Most of the lower cost digitals do not have hysteresis controls. Some are set for 0.5 degrees and some at 1.0 degree. Because of the lower volume of air and the lower R level of insulation as compared to your house, it is easier on the equipment if you can set the hysteresis at 2-3 degrees. If you have control, it will be programmable via the menu.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 05-05-2015, 05:51 PM   #20
I checked manual and back of thermostat there is no way to adjust that setting
thermostat
