Old 05-08-2015, 03:36 PM   #21
Do u have a swing setting? This is another name for how wide the temp will fluctuate before cycling the hvac. Luxpro has it variable from 1 to 10 deg F
2014 Windjammer 3025W Diamond 34.5 ft 8300 lbs.
2010 F150 SC XLT 4x4 5.4L, 3.55 gears 20" rims
12 k Equalizer WDH, Firestone Airbags, HD Bilsteins
TST 507RV TPMS
Zolin is offline   Reply With Quote
Old 05-08-2015, 03:42 PM   #22
Golfnbike13's Avatar
Negative ghost rider. The only settings I have are listed in the photos of the manual on post #12
Golfnbike13 is offline   Reply With Quote
Old 05-08-2015, 04:01 PM   #23
Golfnbike,
I checked your install manual. I would recommend you go into the setup menu and go to option 3 to turn OFF adaptive intelligent recovery mode. Especially on a new thermostat this setting will turn off and on your system trying to anticipate how long it will take to get to and maintain the set temp. It's nice in a home setting however in an RV I think I would leave it off. Try that. Is this thermostat being used for heat only?
TST 507RV TPMS
Old 05-08-2015, 04:07 PM   #24
Sorry, that is option 6 based on the manual I was looking at. You press both the arrow buttons simultaneously and hold for 3 sec then cycle through the options by using the arrow keys. Do you have an option 6?
TST 507RV TPMS
Old 05-08-2015, 04:09 PM   #25
No, I only have the options with the star written beside them. The manual is for several different models. It is a heat only thermostat.
Old 05-08-2015, 04:12 PM   #26
If not, I am out of suggestions other than returning it and purchasing an inexpensive Luxpro digital programmable off Amazon where you will be able to control the swing and cycle frequency. I had this setup on my hybrid where I was using it for the heat only function. I sold my Hybrid and transferred it for full usage on my new Windjammer with heat and AC
TST 507RV TPMS
Old 05-08-2015, 04:30 PM   #27
That's what I'm thinking. I'm just shocked because this one had so many good reviews from TT owners and Honeywell is a great brand. I may try it one more time before I uninstall it, but it's gotten so hot here I don't know if I can get the inside temp low enough to kick on.
Old 05-08-2015, 09:24 PM   #28
I understand that. Sorry that happened to you. Make sure you have selected option 5 for gas. I know another post stated that but it's worth checking again. There is a possibility you have a defective thermostat also.
TST 507RV TPMS
thermostat
