Old 08-29-2014, 07:31 PM   #1
Golfnbike13's Avatar
Is battery dead?
I've had my TT plugged to shore power for days but as soon as I unplug it the battery is dead. Shouldn't it charge when plugged in? Or do I have to use a battery charger? It's only a year old so I wouldn't think it's bad.
If I have to use a battery charger will a regular car battery charger work?
Golfnbike13 is offline   Reply With Quote
Old 08-29-2014, 07:35 PM   #2
markb5900's Avatar
Check your fuses.
It should charge off the shore power, but more than likely you have a blown fuse so it isn't charging if the battery is only a year old.
Mark B
2015 32 Foot Rockwood 8289WS 5th Wheel
2017 GMC 3/4 Ton TV
markb5900 is offline   Reply With Quote
Old 08-29-2014, 07:40 PM   #3
Bingo. Found a blown fuse, replaced it and battery was fully charged. Thanks you saved me a headache!
battery
