Make sure everything is working before final acceptance and payment, do a proper PDI check that fridge works on electric and propane, hot water tank works with electric and propane, check AC and furnace are functioning, check stabilizers, check awning for function and holes, get on roof and check to see if all appears well, check windows for proper operation, check fit and finish of all finishes, check televisions for operation, check all lighting inside and out, check plumbing for leaks, fill fresh water tank and check water pump and for leaks, hook up to city water connection and check for flow at all point of use and check water filter, check stove and oven for function, check micro wave, make sure you understand how to operate all devices, stabilizers are not jacks merely for stabilizing the trailer, check 12 volt lighting with out shore power connected, there are not any dumb questions, locate battery disconnect and understand it still has small devices sucking power even when in disconnect position. Do not be in a hurry they will rush you enough, do not accept till you are comfortable with the quality and knowledge obtained.
GMC Denali 2500HD 4x4
Columbus 381 FLC 2016
Flagstaff Ultralite 29 RLSS
2013 35 nights, 2014 105 nights, 2015 123 nights, 2016 18 nights 🙁
