Old 04-29-2016, 03:23 PM   #1
PA1904's Avatar
Landing gear
I can't find schematics or a second fuse box. I have a 368rlbh, and my landing gear stopped working. It's gotta be the switch or a fuse. Any ideas on location?
-04' Ram 3500 DRW
-15' Hemisphere 368RLBH
-2004 Ram 3500 DRW
-2015 Hemisphere 368RLBH
PA1904 is offline   Reply With Quote
Old 04-29-2016, 03:38 PM   #2
Head Rambler
Mine has an inline fuse hidden in the wire loom behind the battery. It took me a while to find it when it blew from a dead battery.
Gotta go campin!
Old 04-29-2016, 03:51 PM   #3
Open the front cabinet door, find the jack motor and follow the red wire.
donniedu is offline   Reply With Quote
Old 04-29-2016, 04:46 PM   #4
PA1904's Avatar
Thanks, I'll check.
-04' Ram 3500 DRW
-2004 Ram 3500 DRW
Old 04-29-2016, 06:00 PM   #5
PA1904's Avatar
I did all of the above. No fuse in line. The switch and the motor aren't getting power. Broken wire?
-04' Ram 3500 DRW
-2004 Ram 3500 DRW
Old 04-29-2016, 08:18 PM   #6
Tfort's Avatar
I have heard people speak of another fuse box behind the wall of the passthrough storage area behind the stairs on the hemispheres but I have not taken mine loose to verify it yet. Not sure if this fuse will be there or not.
2000 F250 CC 4x4 7.3L diesel
15 Salem Hemisphere Lite356QB
Tfort is offline   Reply With Quote
Old 04-29-2016, 08:26 PM   #7
If you try to run the front and Rear landing gear will blow the inline fuse. Fuse is located right by the battery box.
Buffalo2VA is offline   Reply With Quote
Old 05-02-2016, 10:16 AM   #8
Head Rambler
The positive wire should run straight from the battery to the switch, thru a fuse. If you traced the positive wire from the switch all the way back to the battery and didn't find a fuse then it is possible that one of the pieces of wire is a fusible link and has opened. Though I don't think I've ever heard of an RV having those.
Were there any connections/terminations between the switch and the battery?
Gotta go campin!
