Old 09-10-2015, 03:22 PM   #1
lci remote
I have a 2015 Forest River Salem Hemisphere. The LCI remote works for everything but, the front jack only works on the remote, not the switch itself. I used ohm meter on the switch, it tests OK. Any ideas?
Mike
mikebecker80 is offline   Reply With Quote
Old 09-13-2015, 06:15 AM   #2
Not sure if you are talking about the touch pad tablet or not but that is what we have. If you use the touch pad to open then you also have to use it to close. We have had all kinds of problems with our tablet. Bought our RV this past March and have had it back at the dealership since. They were just able to fix the touch pad and delivered RV back to use this past Friday.
Lorihmartin is offline   Reply With Quote
Old 09-13-2015, 08:09 AM   #3
Head Rambler
That a common problem.
Look for a fuse in the line from the switch to the battery. They're usually hidden behind the battery.
On mine, I can use either the remote or the manual switches interchangeably. For example, I can run the landing gear down, or part way down, and then use the manual switch to run it the rest of the way down or back up.
Gotta go campin!
Bama Rambler is online now   Reply With Quote
