Old 03-16-2016, 03:21 PM   #1
familytherapy's Avatar
lci Wireless Transmitter Location
Good afternoon! I have a 2012 Salem 30QBSS with the LCI wireless remote for the slide out, stabilizer jacks and the awning. I just finished "de-winterizing" it and while trying to use the remote to operate the slide out, etc., I cannot get the remote to actually get past the main screen. I hit the large silver button at the bottom and the screen comes on where you can hit the "ok" button, but when I touch the button, nothing happens (see the attached image). I cannot get off this screen. Has anyone experienced this before? Does anyone know where I can find the transmitter? Thanks for the help!
Name:	LCI remote.jpg
2012 Forest River Salem 30QBSS
TV - 2015 Dodge Ram Big Horn Hemi
familytherapy is offline   Reply With Quote
Old 03-16-2016, 04:11 PM   #2
Head Rambler
Once you press 'OK' you're not asked for a pin?
Our receiver is located under the oven, some are under the fridge, and others are in a cabinet. They're really all over the place. It seems there is not rhyme or reason in placing them.
Try pressing the silver button 5 times and see if it'll go into config mode.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 03-16-2016, 04:14 PM   #3
Head Rambler
Also, try completely disconnecting the battery and reconnecting it after a minute or two.
Gotta go campin!
Old 03-16-2016, 04:23 PM   #4
I hit the ok button, but nothing happens. It's like the screen doesn't recognize that anything is being pressed. I can get to the config mode, but same thing, when I hit the config button, nothing happens. Hope the remote isn't broken.
Old 03-16-2016, 04:40 PM   #5
Head Rambler
Try disconnecting the RV's battery(s) for a few minutes. I read where that resets the receiver and causes the remote to start operating again.
Gotta go campin!
Old 07-20-2016, 02:57 PM   #6
I have a 2012 Coachman Freedom Express with the LCI remote system on it from the factory. It works great and I have second remote I want set up, but I can not find the receiver unit to program the new one, does anyone know where it may be ? I have looked in the usual places. Thanks
CREDEATION is offline   Reply With Quote
Old 07-20-2016, 03:07 PM   #7
Head Rambler
I assume that you've checked all the places listed above. Turn off all noise makers in the unit and using the remote on a light function or other function that doesn't create noise inside the unit and go around clicking the remote and listening for a faint 'click' of the relay.
Don't be afraid of looking in some crazy places. Ours is under the oven at the very back of the unit.
Gotta go campin!
Old 07-20-2016, 03:15 PM   #8
Angry LCI location
I have talked to the coachman engineers and they said it was behind the breaker and fuse panel, my luck it was not. I have looked under the stove ,sinks, storage spaces, and no luck. I am trying to set the second remote up and pair it to the receiver. It seems to be in stealth mode,lol.
Old 07-20-2016, 03:46 PM   #9
Head Rambler
Do you have an enclosed underbelly?
Gotta go campin!
Old 07-20-2016, 03:49 PM   #10
yes insulated and enclosed, I was hoping not to have to look under there. Looks like a mess to do....
cat, location
