Old 05-03-2015, 04:58 PM   #11
Done with this
The black/silver color was just from being blown. It should pull out, just wear gloves.
I'm a little too truthful, I guess.
Y'all have fun in "Fantasy Land".
4mula1fan is offline   Reply With Quote
Old 05-04-2015, 05:13 AM   #12
It would really help if I had a picture to shoe me what to grasp to pull it out. Why oh why does everything have to be so complicated. Haven't a clue as to what I am doing
Sandy and Steve
Chooie, Baby, Grizzly, Sophie the 4 fur babies
2018 Rockwood 8301WS fiver
2003 Ford F-250 super duty diesel
Vinemont, AL
Triple SS is offline   Reply With Quote
Old 05-04-2015, 06:11 PM   #13
Got the bulb out so now off to Walmart in the am to check for replacement
Thanks for all the help
Sandy and Steve
Vinemont, AL
Old 05-18-2015, 02:00 PM   #14
I replaced mine with a 12v truck domelight. much brighter mounted it to same bracket with self tapping screw and used existing power lead.
mstrausbough is offline   Reply With Quote
Old 05-20-2015, 08:59 PM   #15
Kungfu01's Avatar
Mine blew after about 15 minutes as well. I was rather turned off that it blew so quickly. I think it is a 4 watt bulb and I replaced it with a 7 watt with no negative effects to the wiring that I can tell.
- 2015.5 Salem 30QBSS Show Stopper
- Previous 1999 Skamper Lite by Thor
Kungfu01 is offline   Reply With Quote
Old 07-07-2015, 10:36 AM   #16
I used one of these LED lights: light
one screw ( don't lose it ! ) secures the wiring cover
turn off power (easiest way is to flip main house Battery switch PLUS no shore power )
red wire goes to white wire bundle ( B+ )
black wire goes to lower terminal of light switch (light switch pops out by pressing tabs in back)
to keep light from glaring off range and/or glass range cover I positioned it about 2" back from aisle edge of hood between the wiring cover and the sink end of the hood
it does get quite warm, so I only use it when really needed
http://www.ipolyi.com/rhlight.jpg
http://www.ipolyi.com/rhlightp.jpg
ipolyihh is offline   Reply With Quote
light
