Old 09-14-2019, 06:34 PM   #1
Lippert 3.0 Auto leveling jacks
How do you access the control panel on the interior of the unit without extending the slide?
2019 Salem Hemisphere GLX 378FLClick image for larger version
nduszynski is offline   Reply With Quote
Old 09-14-2019, 06:46 PM   #2
Cant help with the exact answer but on my Sabre 36bhq, I use the outside controls mostly. I use the inside controls only for very minor tweaks.
If I were in your predicament, I'd use outside controls to auto-level, slide out slides, and then maybe tweak leveling with inside controls if necessary.
Skip12 is offline   Reply With Quote
Old 09-14-2019, 11:09 PM   #3
Fulltime family RVer
If it’s blocked by a slide, there’s nothing you can do.
But, mind if I ask why you’re wanting to control it from inside?
Old 09-14-2019, 11:15 PM   #4
Welcome to the forum from Central Florida. You will get good advice here.
2016 Siverback 33IK
Old 09-14-2019, 11:24 PM   #5
frank4711's Avatar
Not sure why you would want to ... we level and stabilize before we ever open door and adjust steps and open slides ... my only panel for auto level is on the inside wall of the pass thru storage ... best of luck
Frank & Cindy *** Rockwood Ultra Lite *** 2019 Ram *** Remi & Sage traveling Pomskies *** TST 507 TPMS *** B&W Patriot 18K *** 3.92 axle *** Goodyear Endurance *** 32 days camped 2019 *** Predator 3500
frank4711 is offline   Reply With Quote
Old 09-14-2019, 11:38 PM   #6
I see this is your first post. Do you know you have an outside panel? The first stage in learning is you don’t know you don’t know. Maybe you don’t know? Just give us a little more info and we can help you out. Again, welcome to the forum.
2016 Siverback 33IK
Old 09-15-2019, 08:04 PM   #7
I am unable to use the outside controls. It keeps throwing a fault. It can only be cleared from inside.
Old 09-15-2019, 08:08 PM   #8
There is an issue with the front left jack. It's not moving. We dropped the 5th wheel off at the dealership on our way home.
Old 09-15-2019, 08:08 PM   #9
Mine will clear faults when Hitch Height & Retract All are pressed simultaneously. Hope that helps.
Old 09-15-2019, 08:41 PM   #10
Retired JSO's Avatar
Use the phone app to clear error codes. https://www.lci1.com/onecontrol
Retired JSO is offline   Reply With Quote
Old 09-16-2019, 06:59 PM   #11
How do i find the SSID and password? When i search for a network nothing is found. I tried both wifi and bluetooth.
jacks, leveling
