I have a 2017 Salem Cruise Lite 171RBXL. I need to winterize. Can anyone tell me where the water pump is located? Anyone have a schematic drawing of the water and electrical systems?
Thank you.
Lois Gardner
find you pump by turning on the water to a trickle and follow the noise from the pump as it starts and stops. You are out of luck with schematics of anything on these rigs.
Retired Navy
2016 Flagstaff 26 FKWS
Thanks for replying. The pump also does not have a winterizing hose..and the hot water heater has a different bypass setup(only 2 valves). I found a local mobile RV mechanic who came and winterized the trailer. It only cost $40 which was $40 less than my dealer wanted and I didn’t have to hitch up and drive 35 miles to get there plus gas!
