Old 11-01-2015, 12:53 PM   #1
low water drain leak
One of the low water drains on our Salem 26Tbud has been leaking all season. I have been dealing with it by taping it off with rubber tape from home depot. Now that the season is over and I have winterized the camper, I would like to prep for the repair next season. It looks like PEX pipe, can I use regular PEX materials to repair it or are the special RV components I need to use?
campman2015 is offline   Reply With Quote
Old 11-01-2015, 01:02 PM   #2
Ford Idaho's Avatar
If it is the cap that is leaking you may have lost this.
Ballcock valve seal.
Flair-It 3/4" Saniprene 10 Pack of Ball Cock Seal - Plumbing Fittings - Plumbing
Check with a local RV parts dept.
IF this is where the leak is.
Old 11-01-2015, 01:18 PM   #3
Thanks fo responding. It seems like it's actually leaking from where the threaded connection attaches to the hose. The water seems to stream out while under pressure. I was thinking of replacing the existing fitting with an inline valve.
Old 11-01-2015, 02:40 PM   #4
Ford Idaho's Avatar
Replacing the cap with a 1/2 inch ball valve is what some people have done because it is easy to turn the valve.
I would cut off the end of the Pex where it was crimped for fresh Pex.
Old 11-01-2015, 02:42 PM   #5
Will do, thanks for helping out.
drain, leak, water
