Old 08-04-2018, 07:03 PM   #1
lower led lights
still checking out our new 241qbxl and missed how to turn on the lower led lights.
the switch by the entry door just above the floor does not seem to do anything.
thanks for helping this dumby
nedlob is offline   Reply With Quote
Old 08-07-2018, 06:32 AM   #2
That is the switch that operates my lower “blue” led lights on my 2018 27RKSS. I did have an interior led strip light that didn’t work, turns out it was wired backwards from the factory. Just a thought.
Sparky817 is offline   Reply With Quote
Old 08-07-2018, 11:19 AM   #3
That switch operates mine on the 171rbxl (your little sister/brother).
Turns out the wire connections came loose.
Look under your trailer where the LED light strip wires enter the cloth membrane.
There is a crimp wire connection here that comes loose. Recrimp the wires and hopefully this solves the problem.
And yes mine worked at the PDI - but came loose before the first overnight stop home.
Mark Duerst
Raleigh NC
2019 Wildwood Xlite 171rbxl
2018 JGC Limited 4x4 w/tow
MarkDNC is offline   Reply With Quote
Old 08-12-2018, 12:23 PM   #4
MarkDNC - you were "right as rain." Both wires were disconnected.
