Old 01-15-2016, 05:36 PM   #1
Bill Scott
MFCO 1000 Watt WF5110H question
I have a Salem Hemisphere 337 BAR and the only thing I know about it I learned from RVing in 90s.. The invoice says it came with a 10.5 Cu Ft Whirlpool Residential Refrigerator, Type 11MTKA w/inverter.
Now I am assuming that the inverter is the one listed in the title (above) that is installed inside one of the bays under the coach. It's been OFF every since I took delivery of the unit. The manual for the refrigerator says it will switch to the inverter automatically when the shore power is disconnected. I assume also that it only does this if the inverter power is turned ON. I am further assuming that if I leave the power set to ON, it will switch automatically, but if I leave the Power OFF, nothing will happen whether I am connected to shore power or not. The refrigerator will have power when plugged in or it won't have power when not plugged in.
Further, I have read that on a long pull, the use of the inverter could drain the battery(s). However after a nine-hour pull with the inverter off, the food was still frozen solid and I see no real need to run it. Maybe that will change in the hot summer months.
I guess my questions are 1), is what I wrote true, and 2) does the inverter supply power to all of the 120V receptacles or just the refrigerator?
Thanks in advance for any advice.
BillScott is offline   Reply With Quote
