Originally Posted by grandpaofthree
Wow, sorry to hear about all of the issues. If it helps a number to reach Forest River is 574-642-2640
Salem's rep is Tony Hufnagle.
517-534-3167 or 574-537-1175 direct
Don't tell him I told you
because I'm hitting him for a kitchen faucet which leaks, a broken tongue jack, a slide out which has rubbed its way through the siding in the corner and a fitting to the galley tank which needs replacing (only replaceable with the the tank itself being replaced).
Thats in addition to the 5 tires which were defective, the door lock which would but not unlock, the awning clips which were broken, the window trim which became a javeln, the air pockets under the rubber roof (think I found the missing wrench under it...
